3 point hitch one bottom plow
/ 3 point hitch one bottom plow #1
Buggs67
Perry Cty, Pennsylvania
Kioti 2014 CK2510 TLB
I found this listed on Craigs list. I don't need it now, but will in the future f or a food plot. Is $100 reasonable. I don't have much infor and it looks rusty but not abused. Thanks In advance.
/ 3 point hitch one bottom plow #2
Good price, if it were closer to me, I'd take it for that price.
/ 3 point hitch one bottom plow #4
That's worth a hundred bucks any day;looks in good shape.
/ 3 point hitch one bottom plow #5
Could it be a cat 0 plow and maybe a little small for your tractor and maybe a 10" share?
/ 3 point hitch one bottom plow #6
I agree that plow MAY be for a tractor with Cat 0, rather than Cat 1 hitch. Plow fit to tractor is important.
Thanks all.
I sent a message to him asking for more info. No reply yet. With my 25hp I figure I should be able to pull a midsize plow. It will depend on the soil(rocks). I figure if it's a little small I could turn it twice? New to this.
/ 3 point hitch one bottom plow #9
Thanks all.
I expect you can pull either a 12" or 14" plow if the plow ground contact parts are not worn and free from rust. After "breaking" new ground it will be rough. Traditionally, a Disc Harrow is the next implement pulled over plowed ground, followed by a drag of some time to finish smoothing. For food plots, particularly if the plow is just 10", a Cultipacker may work rather than a Disc Harrow.
Food plots due not have to be as smooth as a field. Food plot seeds are generally strong germinators.
If you want to read more on plows and plow adjustment, here is a LINK:
http://www.tractorbynet.com/forums/...oard-plow-wisdom-farmwithjunk.html?highlight=
Galion T-400 Motor Grader (A65579)
Galion T-400 Motor...
KUBOTA KX080-4S2 EXCAVATOR (A64277)
KUBOTA KX080-4S2...
Case IH 5100 (A64119)
Hydraulic Pump (A65640)
Hydraulic Pump...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
