ATV Trailer Build
/ ATV Trailer Build #21
Something you might want to consider. When I built my walking beam hunting trailer I set the beam pivot point a little to the rear so the the front tire could easier walk over obstructions.
/ ATV Trailer Build #22
I was planning on using a 50mm ball hitch (I think that is slightly bigger than 1 7/8in). I think walking beam suspension is decided. It is going to be used on a pretty rough road, in performance I don't think a single axle would compare. I am building it with a walking beam because of the suspension advantages not the weight carrying advantages.
A 50mm ball is about the same size as a 2" ball (1.96"). I would HIGHLY recommend going with a 2" ball over a 1 7/8" ball as its too easy to put a 2" trailer on a 1 7/8" ball and a 2" trailer can just bounce off...
Aaron Z
/ ATV Trailer Build #23
I believe the use of 1-7/8" balls on NEW trailers is finished, you just don't see any out there even on the smallest trailers.
I think your walking beam is a great idea, if I may recommend you use a solid bolt for strength then have your grease point in the actual bore of the beam and a groove machined into the bore of the beam for grease to surround the bore. The bolt with a zerk installed will really weaken the bolt itself.
I wouldn't overbuild the trailer too much as empty weight is not your friend. You can buy square tube with .090" wall (about like exhaust tubing) that would work well for a frame.
Regards, Fred
/ ATV Trailer Build #25
Look up Tundra Tuffy. I have a friend that makes these in Ak. He has a clip on you tube. Has made several and they work well. He is now in Wa State. Anyway, this will give you some good ideas about your build.
/ ATV Trailer Build #27
The point to a walking beam is not to carry more weight, but to smooth the ride for the load, as well as remove some shock load from the tow vehicle. I like my trailer, but I have to slow way, way down when carrying some things where I could travel a little faster & smoother with the walking beam.
/ ATV Trailer Build
Thanks for that I think that is a good idea.
I appreciate what you are saying, but I don't really have the facility to do that. The trial was a 1/2in bolt with a reasonably large hole, the real thing will be a 3/4 bolt with a very small hole say 1/8in would that still not be strong enough?
/ ATV Trailer Build #30
I ditched of all my 1 7/8" receivers (and balls), put 2" balls and receivers on everything. It's easier that way. Then I got a trailer with a 2-5/16". But that's OK, all standardized except one.
I like walking beam for trailers, as mentioned much smoother ride and easier pull over obstacles. But more difficult to block from rolling downhill,,,,
/ ATV Trailer Build #31
That country mfg design doesn't look right, seems as though it could just fold under? Am I wrong, and it will balance instead?
/ ATV Trailer Build
Progress has been a bit slow. I got the base of the bed done a few weeks ago but didn't get anymore done until today. I also welded caps on the ends of some of the main beams. I did the end of one of them and filled it with water... and it held I was pretty impressed considering the 15yo novice welder that I am. Anyway here are some pics of today's progress. IMG_20141118_183919.jpgIMG_20141118_184013.jpgIMG_20141118_184056.jpg
/ ATV Trailer Build #33
:thumbsup: Looking good!
/ ATV Trailer Build #34
Yes looking good. I would think a 3/4" bolt with 1/8" lube hole would work fine.
Regards, Fred
/ ATV Trailer Build
I hope it will because I haven't thought of anything else.
I made up the hinges for the dump box this morning, I hope to get them attached to the box later on. Then I can attach the main beams.
/ ATV Trailer Build
I got the hinges attached and also attached the main beams at one end, sorry no pics yet. I will post pics soon.
/ ATV Trailer Build
Creating must be in your blood
I don't know about that, but I must admit I do like creating things. The hardest thing is knowing what to make and funding it...
Here are the promised pics, sorry they aren't really that good.
/ ATV Trailer Build
I finally got some more done. It is on wheels :cool2:
/ ATV Trailer Build #40
:thumbsup: Looking good.
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
213086 (A64276)
213086 (A64276)
CAT 320 Excavator Compactor Wheel (A68134)
CAT 320 Excavator...
2021 JOHN DEERE 333G SKID STEER (A65056)
2021 JOHN DEERE...
2015 Ford F-450 Knapheide Service Truck (A66736)
2015 Ford F-450...
Unused 2021 Tufline BCP2416 8ft. Cultipacker Tractor Attachment (A66734)
Unused 2021...
