drewbarnett
Which way does the long hub on the clutch disc for a Mahindra 4110 face, toward the flywheel or toward the release bearing?
did you replace the pressure plate? Is the new disk real thick? The correct one?
Have you adjusted the linkage to it's shortest position and worked it back from there?
I assumed they fingers were already adjusted to the correct height since the owner had been using the tractor for a couple of years. That could be the problem though. Do you know what the correct setting is?
