Good morning!!!!
   / Good morning!!!! #26,551
Poured first cup of coffee. 22° with light snow this morning. Heading to 32° with some sun. Got the trench filled in. What a mess. Frozen clumps of clay. Will need to go back in spring and level it out. Going to grease tractor and FEL. Then install Snow Blade. That finishes off all my fall projects.
Good Morning All.
   / Good morning!!!! #26,552
29F and cloudy @ 06:00 ...
Supposed to be sunny with a high of 36F today ... so I might give getting something done outside today a shot. Still have more a lot more leaves to pick up around the barn, and the yard could be run over again, given that the oak leaves are continuing to come down.
Went down to Cross Truck Equipment and picked up 2' feet of 6" tube to extend the wood chipper discharge chute and snagged a couple of 3/8" shackles and 1/4" spring lock pins for some parking stands while I was there ... also grabbed a can of Fluid Film. This will be the 1st time I've ever tried this "miracle fluid" ... I hear everyone talking about it, so I figured I better check it out and get with the program.
And I ordered the flanges (which will allow the chute to rotate 360 degrees) from McMaster (along with a 24" x 24" piece of expanded metal for the brush guard on the Kubota) ... they should be here Monday, if not today.
Raising the discharge chute by 2' should allow me to shoot chips into the dump cart ... although I may have to hinge the chute so it can be lowered to get it inside the shop, since the overhead door is only 7' tall.
Replaced all the funky Chicom grease fittings on the chipper yesterday and got the feed roller pulled along with cutting off the handle that raises it. Looks like it will need bent a little to line up with where I intend to place it. Experimented a little with sharpening the teeth on the feed roller ... tried using my little 3" air-driven cut-off tool ... wasn't happy with how that turned out ... think they are going to have to filed by hand with a triangular file.
Did a bunch of clean up in the shop including the main workbench ... probably can now actually be used to work on something ... lol ...
Hope everyone has an enjoyable and productive day.
   / Good morning!!!! #26,553
rswyan forget to fill bird feeder yesterday wife said birds were flipping me off naughty me
LOL ... just wait until Mrs. Red Bird gets ahold of ya ...
They have been swarming around the feeders here since I filled them ... we've been getting a dozen or more at any given time hitting the two Nyjer feeders and the suet cage that is just outside the living room window ... with usually a few more waiting in the wings for a spot ...
The day after I filled the two tube feeders with black oil sunflower seed they were already half empty.
   / Good morning!!!! #26,554
19F snow flakes dancing in the air,mid 30's for high temp low 20's night time temps...looks like mother nature will make ice again to night.
Looks like putter day,dump run..get little wood in,clean woodstove,dig out snow shovels etc. etc.
Enjoy the day all.
   / Good morning!!!! #26,555
21 this morning high of 43 later. Yesterday was brutal sense we were not used to the cold but no snow just windy and never got above 36.
If wind doesn't blow time to get up leaves
rswyan some days have to fill feeder every day others every other day. Ran a bluejay off this morning as they keep the small birds away
   / Good morning!!!! #26,556
Interesting ...
We've got bluejays here ... quite a few of them in fact ... and I mean right around the house.
But for some reason or another they don't seem to come to the feeders all that much ... at least that I've noticed. Of course, other than the suet cages, there's only one feeder that they could realistically use ...
   / Good morning!!!! #26,557
Good morning, temperature here is the same as Roy's and Ron's, 22F high in the same area as well, 34F. No wind to speak of here this morning so the temp doesn't feel that bad.
   / Good morning!!!! #26,558
A smoldering 40* this morning, headed to 52. Cloudy with a chance of rain. Spending the morning indoors teaching a class (Volunteer work with high school students). Will try to get some outdoor work in this afternoon, but with everything going dormant, not too much to do. Plus with the chance of rain, my outdoor options may be limited by nature. Same outlook for tomorrow, so the weekend may be a lost cause.
   / Good morning!!!! #26,559
25 degrees sitting in a tree staring at the sun in beautiful crime free Blue Mountain, Mississippi
   / Good morning!!!! #26,560
24 this morning and headed to 42 today. Will be working on building today.
CASE MXM 190 TRACTOR (A58216)
CASE MXM 190...
Attention (A57148)
Attention (A57148)
2011 Mercedes-Benz E-Class Sedan (A56859)
2011 Mercedes-Benz...
2016 Isuzu NPR 18ft. Box Truck (A56858)
2016 Isuzu NPR...
1994 CAT 322L (A55272)
Mini Skid 48in Root Rake Grapple Attachment (A56436)
Mini Skid 48in...
