Price Check L3800 price check
/ L3800 price check #1
grumpyoldman
Pennsylvania
Kubota B2320 HST w/ FEL, Kubota L3800F, Ford 8N
This is my first post. I have been lurking for a while working on my 8n (thanks for the help on that), but I'm starting to get a bit tired of tinkering with it constantly to keep it going all year round for bush-hogging, plowing, and skidding logs.
I was in to my Kubota dealer (I have a b2320 hst with fel) and saw a L3800 gear 2wd. I got a quote including 275lbs in front weights, loaded rear tires, and ktac insurance for the 0% 60 month finance ng. The quote was $14,412 including $753 in taxes. Does this sound like a good deal (at least for pa)? Thanks in advance.
Brett
/ L3800 price check #2
That was new? I got a quote of about $19,000 for a L3800 w/ loader and 4WD, gear shift in 2010.
/ L3800 price check #3
grumpy,
If you are decided on the tractor, then you need to get quotes from other dealers. Anything we say is just jibberjabber.
/ L3800 price check #4
Ummm...
If that is an accurate quote then it seems to be a great deal.
/ L3800 price check
Yes, it's new. Last L3800 they have. I was going to try another dealer this weekend while I was out.
/ L3800 price check #6
if i was you id get 4x4 on that 3800.you will love having a 4x4 tractor.
/ L3800 price check #7
Sounds okay with a loader. If that is without a loader, seems high.
/ L3800 price check #8
I agree 1000% with bigbull. Kubota compacts are lightweights. For a general use compact agricultural tractor, 4x4 is the only way to go.
/ L3800 price check #10
Not sure what kind of terrain he has where he lives, but a 4x2 tractor here in Branson (noted for hills) is totally useless.
/ L3800 price check #11
I agree that 4WD is awesome, but if this tractor will replace a 8N, then 2WD will still be fine to pull logs and brush hog.
/ L3800 price check #12
I paid 15k for my L3800DT 4wd, loaded rears, w/loader, with 14 hrs on the meter three years ago. It's a keeper!!! Believe I would shop around some more.
/ L3800 price check #13
A Kubota dealer near me has two Mx4700's 2wd. One has 27 hours and the other has 63 hours. Both are rental returns and both can be had for 14,000. I think they still qualify for new financing and I'm sure they'd throw in loading the rear tires.
/ L3800 price check
Thanks for the replies. I'll definitely be looking around some more. This gives me a good direction to start.
/ L3800 price check #16
I've recently ran into a few problems with my L3200 in 2wd even with loaded rears.
My barn now has a pair of pallet forks sized holes in the wall in back... I figured I'd be fine on a 5-7 degree slope dropping off a maybe 200lbs metal coral panel. I have loaded rears & that panel isn't even 20% of my rated lift capacity, so I didn't bother putting on my box blade for ballast. Well apparently that was enough to leave some nice skid marks because I wasn't in 4wd.
These new CUTs are designed & balanced for 4wd, unlike the old generation which was designed for 2wd with a lot more junk in the trunk. Unless its just pulling a mower on flat ground I wouldn't want a 2wd Kubota.
/ L3800 price check #17
yep, I agree completely.
/ L3800 price check #18
If no loader (FEL), these smaller tractors are fine in just 2wd. Add a loader & I want 4wd, But counter weight on the 3 pt is even more important... ;)
/ L3800 price check
So, I got a quote on a 4x4 L3800 that was a few thousand more, and after consulting my bank account, I think I'll just look for a heavier older tractor for my bush hogging. The B2320 with fel that I have should handle the rest. Thanks for the replies. Would have been nice to get a nice shiny new tractor, but I just can't justify the cost right now for the amount of use I'll get out of it.
/ L3800 price check #20
You can get good deals on the older iron. That's the road I would take for brush hogging.
