John Deere- hand speed control lever
/ John Deere- hand speed control lever #1
omidon
Summerfield, NC
2640 john deere
Does anyone know how to replace the friction disk on the hand throttle control on a John Deere 2840.
/ John Deere- hand speed control lever #2
First, clean any rust from the exposed throttle control shaft under the friction discs. Then spray some penetrating oil on all components from the friction discs down. Drive out roll pin #14 and remove the lower lever #1. Then back off nut #12 and let spring slide down. Drive out the 2 lower #9 pins form the threaded sleeve and the lower friction disc retainer #8. It will probably take a lot of patience (and cursing), but try to slide down the threaded sleeve, spring and friction disc retainer. It might take a little heat to free them up. be careful with heat on the disc retainer because it is aluminum and will melt easily. After these items are slid down, you can pull up on the shaft and slide them all the way off. Then you need to remove the last 2 pins in the upper disc retainer and the throttle stop screw bracket so the shaft can be pulled out the rest of the way. Then you can put the new friction discs in as you slide the shaft back down through all the removed parts. Reassemble with new pins and adjust nut for desired tension. Sometimes the discs are not actually worn out but the 2 disc retainers get stuck on the shaft and the spring cant slide them together for proper operation. I recommend a small amount of never-seize on the retainers to prevent the repeat problem.
Thanks JD. My #11 spring is broken and one of the #10 disk is split, so the whole assembly will have to come out to repair. I think getting a pin punch lined up to take the roll pins out will be my most difficult problem.
/ John Deere- hand speed control lever #4
My throttle control slips back reducing the RPM and I continuously have to throttle up. I figured you probably have repaired yours by now and wondered how you made out.
Also, can you adjust the tension nut without taken the assembly apart ? My spring is in good shape and I am hoping all I have to do is tighten the nut, if possible
with out taken it apart.
Please advise. Thanks, Duke
/ John Deere- hand speed control lever #5
Yes, you can adjust the nut without disassembly. As long as the lower #8 is not stuck to the shaft it should respond well to adjusting the nut.
/ John Deere- hand speed control lever #6
I took off the side cover to get to the spring to tighten the nut, however, there is no nut to tighten, just a spring. The assembly is different than the one you have
posted. I recently bought this tractor to restore it is a 2240 model, would you have an idea on how to fix this ?
Thank you,
Duke PS: I can't understand why it posted 3 times, tried to delete them but it will not work, appears there is something wrong with this site
/ John Deere- hand speed control lever #7
Thank you,
Duke
/ John Deere- hand speed control lever #8
Thank you,
Duke
/ John Deere- hand speed control lever #9
Thank you,
Duke
You'll either have to replace friction washers or some how shim up the spring for more tension.
R105814 Washer - WASHER, FRICTION ADD 2.61 USD
/ John Deere- hand speed control lever #10
Thank's Jim I'll give it try.
/ John Deere- hand speed control lever #11
The management is aware of the double posting issue and is looking into it.
2021 Ford Explorer Hybrid AWD SUV (A66738)
2021 Ford Explorer...
2025 Swict 72in Bucket Skid Steer Attachment (A66734)
2025 Swict 72in...
2003 PETERBILT 330 DAY CAB (A67714)
2003 PETERBILT 330...
Craftsman 16in Variable Speed Scroll Saw (A64553)
Craftsman 16in...
2020 FREIGHTLINER M2 106 WATER TRUCK (A67714)
2020 FREIGHTLINER...
WoodMaxx MX 9900 with almost no use
WoodMaxx MX 9900...
