Attaching sprocket to pipe
/ Attaching sprocket to pipe #1
taldestra
Midland, Tx
spooler
Im building a spooler for layflat hose. it has a 36 inch sprocket with 112 teeth being pushed by a 13 toothed sprocket and chain, hydraulic motor is being relayed through an OHLA bearing to the smaller sprocket. i dont want to weld the 36 inch sprocket to the pipe because i want to be able to remove the sprocket in case of failure in any way. how can i attach it?
36 inch in diameter
1/2 inch thick
2 1/2 inch hole in center
2 1/2 inch in diameter solid steel pipe
44 inches long
/ Attaching sprocket to pipe #2
shaft turned to fit the pipe welded and a key way, for a hub on the pulley,
/ Attaching sprocket to pipe #5
Weld on a pipe flange to the pipe and then drill/bolt the sprocket to that. Or something similar.
/ Attaching sprocket to pipe #6
How about this? It's about $15.00. You can drill and tap holes in the side to mount the sprocket.
McMaster-Carr
/ Attaching sprocket to pipe #7
For pipe I would use a pipe flange, for a solid bar axle, a weldable hub would be the ticket.
/ Attaching sprocket to pipe #8
You might also want to check out taper lock bushing and sheaves. It wouldn't be hard to adapt a TL sheave to your 36" sprocket and the only thing you need to do is have a keyway milled into your shaft to provide a positive drive.
Going to weld a sleeve to the sprocket and slide it onto the shaft. drill a hole through both sleeve and solid steel pipe, insert locking pin.
/ Attaching sprocket to pipe #10
good plan except, that pin is going to take a lot of shear force.
Shear pins for a baler would make it the weak easily fixable point. IIRC the shear pins for a massey baler were 1/4" with a squished nut. Other than that anything other than a grade 8 bolt is going to break quickly. Don't expect a roll pin or split pin to survive long.
I'm using a grade 8 1" bolt hardened
/ Attaching sprocket to pipe #12
Don't use pipe. Use a DOM tube. (Drawn Over Mandrel). For pipe, the id is controlled. For tube the OD is precise. Then you can shop some TSC parts to put the sprocket and its hub on the tube with a sufficient sized roll pin. I just bought a 2-1/4" DOM tube from an eBay seller for my extra Rol-A-Bin that's true, straight and exact.
If you can find an old hay/grain elevator, the parts you need for a powered hose reel are all there.
AGT Cat 320 Coupler (A65583)
AGT Cat 320...
2017 Ford E-Series FedEx Delivery Truck, 5.4L V8, Step Van Conversion (A63689)
2017 Ford E-Series...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2015 FREIGHTLINER M2 24FT REFRIGERATED CDL REQUIRED BOX TRUCK (A59914)
2015 FREIGHTLINER...
(2) KMC Strip Till Row Markers (A64127)
(2) KMC Strip Till...
23" QUICK ATTACH EXCAVATOR BUCKET (A60429)
23" QUICK ATTACH...
