What is the best 12 volt Battery Charger regardless of cost.
/ What is the best 12 volt Battery Charger regardless of cost. #21
Thanks i personally use a 2,4,8 amp battery minder brand charger. I accidentally deep cycled a 1 year old agm battery in my victory i wish i had known about the midtronics at the time.
i tried to piggy back it with another battery could not get it to take a charge. Ive seen the same thing with test vehicles at work. A Couple hours on this charger and they work like new. Unfortunately its cheaper to scrap out a $130 battery than buying a $2000 charger
/ What is the best 12 volt Battery Charger regardless of cost. #22
/ What is the best 12 volt Battery Charger regardless of cost. #23
This is the one that I use, Optima Digital 1200.
<img src="http://www.tractorbynet.com/forums/files/parts-repairs/395614-what-best-12-volt-battery-charger_top-jpg"/> <img src="http://www.tractorbynet.com/forums/files/parts-repairs/395615-what-best-12-volt-battery-img_9011-jpg"/>
So far, so good. :thumbsup:
Marine Battery Charger | Motorcycle Battery Charger | OPTIMABATTERIES
I did not know about those. I am slowing converting to yellow top Optimas. I have not had a reason to charge one yet, but this charger may be nice to have.
/ What is the best 12 volt Battery Charger regardless of cost. #24
Thanks i might look into one of these
$200 seems reasonable
It will also rejuvenate a deeply discharged AGM battery.
/ What is the best 12 volt Battery Charger regardless of cost. #25
I don't see any offering 8-volt charging?
Since the title was "What is the best 12 volt Battery Charger regardless of cost" - ??
Do you mean 8 Amp charge rate? They have different models with different charge rates. This particular charger is intelligent and will optimize mode for the type of battery. As I have several SLA motorcycle batteries, a LiFeP04 motorcycle battery, and two AGM car batteries, this works with all of them. The Optima Red Top has a max charging rate of 10 A max and the motorcycle batteries are lower.
I have the 4512. They're only about $35. The Pro Logix models cost more, not sure of the benefits. The one I have will automatically sense battery type.
/ What is the best 12 volt Battery Charger regardless of cost. #26
I have Red Tops in my WRX and Outback as it is 14 lbs lighter than the OEM battery and substantially more cranking ability in the cold. An Odyssey AGM weighs 50 lbs: the Red Top 36. Because the WRX is a turbo, the compression ratio is lower and that thing will crank no matter how cold.
But for our minivan and other demanding applications, I try to get the Odyssey brand, also sold by Sears as Diehard Platinum. They're expensive, but work great.
Appreciate the link...
My 8-volt comment was in response to the website... I still have two 8 volts that I may someday convert to 12.
Smart Chargers
With the CHARGE IT! 4500 Series, everything in your garage can be kept charged up and ready for use. Big or small, summer or winter, no matter what type of lead acid battery it utilizes. With multiple charge rates and the ability to properly charge many battery types, CHARGE IT! is your go-to battery service tool for everything from motorcycles and jet skis to cars, trucks, SUVs and more.
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
2022 Fairbanks Nijhuis Commercial and Industrial Water Supply Pump (A59228)
2022 Fairbanks...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
