Your towing rigs and trailers
   / Your towing rigs and trailers #1,861
Here's my tow rig -- 2008 Ford F-350 Lariat 4x4 with V10 gas motor and a 20' Top Hat Gooseneck trailer.
   / Your towing rigs and trailers #1,865
Haven't posted anything in a while, but felt compelled to share my excitement with you guys. I ordered a 2015 Ram 3500, CCLB, SRW, Cummins and 6 speed manual. I was upset with with the 3500 and the 6 speed all i could get was the 3.42 gear ratio, I would have preferred the 3.73 but I figured I should be fine with it. It is a Tradesman model, ordered exactly how I wanted it with vinyl seats and floor. Only options except for the drivetrain that I added were CD player, gooseneck prep kit, clearance lights, and factory added dash mounted auxillary switches. It is granite metallic in color. Didn't talk numbers yet since I was told it would take 8-12 weeks to come in, but the number they gave me was $42,292. Which I don't think is bad at all for the truck. Definitely plan on getting at least down to around $40 hopefully.
I will keep you all updated, if not between now and then I am sure I will have pictures the day it comes in or the day after. You guys have been a long time influence that has helped me think and plan this truck out for about 5 years now, and finally, at 18 years old, I am able to order it, able to afford it, able to use it, and able to take care of it. Glad I am living at the firehouse and have no bills except for truck payment, insurance, fuel and phone that make this possible.
Kyle
   / Your towing rigs and trailers #1,866
Congrats on the new truck. As for the gearing I think you will be very happy with the 3.42 ratio. My dad and I have nearly identical trucks, 07 & 08 quad cab long beds, same tire size, both 6 speeds, only difference is mine has 3.73 and his 3.42. The 3.42 performs better both empty and towing. The higher ratio allows more overlap between gears, places where I'm stuck in 6th unless I want to slow down he can run in 5th.
   / Your towing rigs and trailers #1,867
Congratulations on the new truck Kyle :thumbsup:
It's great to see a vinyl and stick option still out there.
Rgds, D.
   / Your towing rigs and trailers #1,868
This is my rig for towing my tractors and other toys. 2001 Ram 3500 5 speed 4x4, 24 valve. Zero complaints and has pulled anything I've hooked to it. Lately I put a I performance fuel filtration/pump system in it as well as a set of gauges to let me pull heavy without guessing on costly repairs.
   / Your towing rigs and trailers #1,869
Kyle
I would add the factory brake controller. After Market ones don't compare.
Chris
   / Your towing rigs and trailers #1,870
I actually did ask for the brake controller Chris, but my said all the 2500 and 3500 trucks come with them now. It's on my spec sheet as $0 and same with the manual tow mirrors.
Kyle
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
White Metal Roof Panels (A55758)
White Metal Roof...
UNUSED FUTURE EQUIPMENT SEAT (A57193)
UNUSED FUTURE...
2015 Dodge Charger Sedan (A55853)
2015 Dodge Charger...
2014 Toyota Corolla Sedan (A55853)
2014 Toyota...
