273 broken frame
/ 273 broken frame #41
Here you go. My fix for the hood popping issue.
/ 273 broken frame #42
Thanks for the picture.
/ 273 broken frame #43
I've also started a new thread...hope it's not my frame.. :|
/ 273 broken frame #44
I wonder if this problem is on the 293 as well???
/ 273 broken frame #45
I haven't seen it, but will keep a vigilant eye out. Any of our customers interested in heavy lifting were encouraged to look at the T353 or the T433/503 for longevity. Mid-compact tractors often leave a lot to be desired when it comes to anything other than occasional loader work. However, a careful operator can get a lot out of mid and SCUTs.
/ 273 broken frame #46
The 2x2 makes a 90 and is welded between the four bolts that hold the ROPS bar to the bottom the axel. Same on both sides of the tractor. Also not pictured is 1/2" thick steel between both sides connecting them together. Still have room to get to the hydro filter.
Could you post some pics of the other end? How has your fix been holding up? I am thinking of a preemptive strike to avoid the original failure.
/ 273 broken frame #47
Anyone have these issues on later models? T233 or T234 ?
2018 CATERPILLAR CB10 DOUBLE DRUM ROLLER (A65053)
2018 CATERPILLAR...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
Kivel Quick Hitch Skid Steer Attachment (A64553)
Kivel Quick Hitch...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
6' SCRAPE BLADE W/ SLIDE, 3PT (A64278)
6' SCRAPE BLADE W/...
2017 Volkswagon CC Sport Sedan (A64557)
2017 Volkswagon CC...
