I actually like my new gasoline can.
   / I actually like my new gasoline can. #11
I'm buying anything No Spill Jill is selling :)
   / I actually like my new gasoline can. #12
Selling!? She is selling something?
   / I actually like my new gasoline can. #13
Someone sells gas can vents on eBay, drill a half inch hole and install! Work great! No more glug, glug.
   / I actually like my new gasoline can. #14
Most Honda dealers sell No Spill.
There is a retrofit kit "To repair old gas and water cans." If not using the No Spill I use funnels and set the spout aside, totally circumventing the EPA's stated purpose. Spilling fuel is not good for emissions either.
   / I actually like my new gasoline can. #15
No need to go to flea-bay....
Stop in to any automotive parts store, even Wall World probably has them, and pick up a couple of standard tire valve stems....
Procedure
1. Drill 1/2 hole where the old air vents used to be
2. Remove the little valve from the valve stem
3. Pull the valve stem through the 1/2 hole you've just drilled until it seats
4. Remove the valve stem cap when pouring
5. Replace the valve stem cap after use
   / I actually like my new gasoline can. #16
Procedure
Which valves do you use, the milton ones I've tried disintegrate in gasoline.
   / I actually like my new gasoline can. #17
Hi Mike,
Sorry, I don't remember the brand name. They came 2 in a pack so I put one on my gas can and one on my diesel can. I haven't noticed a problem but maybe I should look closer.
   / I actually like my new gasoline can. #18
So a while ago, the spout for my chainsaw gasoline can broke. I have been delaying replacing it, mostly out of fear of the new EPA versions. However, I went to cut firewood this weekend and spilled gas all over my 660 and finally decided to retire the old can, which was about 10 years old. I needed a few things at Home Depot, and picked up a can. I have always had trouble neating fueling up chainsaws, but this new can worked great, no mess. You simply turn a collar and push the spout. Anyone else agree?
No way would I agree. That new design is a POS. I bought one out of necessity, used it one time and the next time, the valve wouldn't open. The collar would just turn then click shutting the valve. I had to remove the valve assembly and now it is just a spout. WHO figured that you need to twist a collar, pull back on it at the same time while trying to hold up 5 gallons of fuel and keep the spout in the filler neck. Biggest bunch of idiots ever that came up with that design.
I don't mind the older type where you slide a switch then you can push down on the handle to open the valve. However it seems that they all should come with some sort of over-pressure relief valve. I have seen mine round up like a ball from setting in the sun in summer (empty) and then suck the sides in due to cold (not good for the plastic)
   / I actually like my new gasoline can. #19
The EZ Pour kit has a snap fit vent that is much more convenient than the tire stem. They have a high-flow version available as well. Some are sold at Tractor Supply.
EZ-POUR Universal Fuel & Water Jug Spout
I've now resurrected a number of old containers I had where I'd lost the spout or cap.
But new, I buy No-Spill, they work great and the handle on the back of the five gallon cans is a lot more convenient. I have both gas and diesel cans.
   / I actually like my new gasoline can. #20
After spilling more gas then I ever wanted to, I just realized that the spout was the problem and no longer use it. I just pour the gas straight from the opening in the can. If I can't get the angle, I use a big funnel.
Eddie
2022 CATERPILLAR D4 LGP CRAWLER DOZER (A51242)
2022 CATERPILLAR...
2015 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A49461)
2015 Peterbilt 579...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A51039)
2014 Doyle Dry...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2011 FREIGHTLINER M2 TANDEM AXLE FLATBED TRUCK (A51222)
2011 FREIGHTLINER...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
