I actually like my new gasoline can.
   / I actually like my new gasoline can. #31
   / I actually like my new gasoline can. #32
I have a couple of the No-Spill cans and Oi like them.
I bought a 5g diesel can and a 5g gas can as well as a 1 g gas can for mixed fuel for the weedeater and stick edger.
   / I actually like my new gasoline can. #33
The no-spill cans work great, if you can keep the O-ring from breaking.
   / I actually like my new gasoline can. #34
No way would I agree. That new design is a POS. I bought one out of necessity, used it one time and the next time, the valve wouldn't open. The collar would just turn then click shutting the valve. I had to remove the valve assembly and now it is just a spout. WHO figured that you need to twist a collar, pull back on it at the same time while trying to hold up 5 gallons of fuel and keep the spout in the filler neck. Biggest bunch of idiots ever that came up with that design.
I don't mind the older type where you slide a switch then you can push down on the handle to open the valve. However it seems that they all should come with some sort of over-pressure relief valve. I have seen mine round up like a ball from setting in the sun in summer (empty) and then suck the sides in due to cold (not good for the plastic)
Not that I can agree with.
Last spring my wife started driving a newer Jetta (gas)and seldom looks at the fuel guage as the other car was a Jetta TDI.
Almost a week later she call that she was out of fuel (she has never ran out of fuel). I was closer to HomeDepo than home and was in need of a newer can I picked one of those PIA units with that valve in it. On sale.... now I know why.
When I went to put the fuel in the car ,the valve would not open. Thinking it was a mans problem with reading instructions, the ladies had a crack at it too. Not a chance it was going to open, so I remover the spout and taped a short piece of 1" pipe in the neck that I had in the truck and got them on the road.
After a few days I looked at the darn thing to see what the issue was and now it pours fine, I cut the valve out to make it normal again.
Al
   / I actually like my new gasoline can. #35
Edit. Bad idea.
   / I actually like my new gasoline can. #36
I use this 40 year old metal can for my mixed fuel:
It's handy for filling saws and trimmers.
That 30 year old can is the cat's meow. :)
   / I actually like my new gasoline can. #38
I thought more about it and realize it is closer to 40 years. I got it in 1976 when we got our first house.
I see you can still get them as vintage gas cans on Ebay.
New Holland B95 Backhoe (A50490)
New Holland B95...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2024 Iron Bull 20' Equipment Trailer (A49461)
2024 Iron Bull 20'...
2023 John Deere 6110M Utility Tractor (A50657)
2023 John Deere...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A51039)
John Deere 5090E...
2008 Ford F-250 Pickup Truck (A50323)
2008 Ford F-250...
