JD 2305 Drive Shaft U-Joint = Kabota?
   / JD 2305 Drive Shaft U-Joint = Kabota? #11
Does anyone know if the u joints on 2320 are the same as Kubota
Kubota U-joint will fit, but a little different than JD. The clips on the Kubota are designed to be on the inside of cap and JD have them on the outside.
But the good news the part #for JD is LVA803335 Spider. this fit 2305,2320, and 4010 compact tractors
   / JD 2305 Drive Shaft U-Joint = Kabota? #12
Correction, I just went out and looked at box-- it jus says plain 410. On other threads, I seen C410 and PUJ410. I asked what one I should use but got no response. The plain 410 in stock fit so that's what I used.
This isn't a universal joint but just the caps correct?
So you saying just install on a 2320 with the snap rings on inside then right?
I had my "kick panel" off to check some relays. Today I thought....I need to check that u joint I've read about. OMG!! SO...SO...glad I did!! One of the caps is missing all the needle bearing. Can't believe the driveshaft hasn't snapped!!
So...I'm here to find solution. I said to myself...I will do a replacement thread to help others.
My tractor has 310 hrs o it....u joint probably never been greased. (I bought it with little over 100 hrs on machine)
   / JD 2305 Drive Shaft U-Joint = Kabota? #13
   / JD 2305 Drive Shaft U-Joint = Kabota? #14
I'm not sure why it double posted↑↑↑↑
Anyhow, its been a few days......I would have thought someone maybe able to chime in???
My tractor is apart and really need to make sure the universal will work with my 2320?
   / JD 2305 Drive Shaft U-Joint = Kabota? #15
order JD part # LVA803335 That is the one I ended up using
   / JD 2305 Drive Shaft U-Joint = Kabota? #16
I have searched but came up empty. I need u joints for my drive-shaft and understand Kabota has them for their machines and are the same as JD. Unfortunately JD only sells the entire shaft at over $500.00 which I just can not afford at this time. Any help with pt numbers would be helpful.
Thanks.
JD spider bearing for 2210/2305 main drive shaft; LVA803335
   / JD 2305 Drive Shaft U-Joint = Kabota? #17
I be ordering. Green parts store has them....love that place!
   / JD 2305 Drive Shaft U-Joint = Kabota? #18
I'm just realizing the search on this site doesn't order by date so I think this is a phenomanally old post. But if anyone comes across this looking for u-joints, I'd suggest taking a look at American CV (americancvstore.com) - they've got a really good range of aftermarket parts.
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
2000 Genie Man Lift (A50322)
2000 Genie Man...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
Caterpillar D5K LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K...
24in Tractor Backhoe Bucket BT4555 (A52128)
24in Tractor...
Walking Floor Trailer (A50322)
Walking Floor...
