JD 2305 Drive Shaft U-Joint = Kabota?
   / JD 2305 Drive Shaft U-Joint = Kabota? #1
Curly69
Henderson County, NC.
2006 JD 2305
I have searched but came up empty. I need u joints for my drive-shaft and understand Kabota has them for their machines and are the same as JD. Unfortunately JD only sells the entire shaft at over $500.00 which I just can not afford at this time. Any help with pt numbers would be helpful.
Thanks.
   / JD 2305 Drive Shaft U-Joint = Kabota? #2
kubota part # 37410-13722 Joint Kit used on JD 2305
   / JD 2305 Drive Shaft U-Joint = Kabota? #4
Does anyone know if the u joints on 2320 are the same as Kubota
   / JD 2305 Drive Shaft U-Joint = Kabota? #5
I have a 2305 ( year 2010 ). About a month ago, I put c410 u joints on both ends. $25 each from NAPA. The gray ting is the zerk in the end cap. I'm able to grease each without any trouble. Each joint came with 4 snap rings. Had to use one of my old ones on each joint to fit around zerk. I also had to take all 4 caps off each joint and grind a 1/16 th off so I could get the snap ring to fit in the grove. ( easier than it sounds). Good luck
   / JD 2305 Drive Shaft U-Joint = Kabota? #6
Pictures?
   / JD 2305 Drive Shaft U-Joint = Kabota? #7
Why didn't you just go to JD and buy new spiders? I had to put new bearing in my u joints a couple years back and had ZERO problem getting the bearings from JD. ---- BUT next time I will consider the NAPA ones with the end zerk, I still cannot get at them dam zerks unless I disassemble the entire tractor!!!!
   / JD 2305 Drive Shaft U-Joint = Kabota? #8
I called JD here in Orlando. It was $49 each. Only JD dealer in town. Plus the wait. I would still have the problem of not being able to grease the zerk while it's on the tractor. I asked on a 2210 driveshaft forum here on TBN if anyone knew the Napa joint part number that would fit. No reply. I went to a store winthe the driveshaft in hand- the c410 fit. ( except for grinding 1/16 th off each post.). I posted pics last month under 2305 driveshaft and how I did it.
I can drop the shaft in ten mins. Maybe 20 mins to install spiders and put back on. I can't tell you how much I love the zerk on the end of the cap. After 5 hours of mowing, I greased both joints with the deck on. Not optional- but can be done.vrs dropping. Best of luck. Bill V
   / JD 2305 Drive Shaft U-Joint = Kabota? #9
Correction, I just went out and looked at box-- it jus says plain 410. On other threads, I seen C410 and PUJ410. I asked what one I should use but got no response. The plain 410 in stock fit so that's what I used.
   / JD 2305 Drive Shaft U-Joint = Kabota? #10
For pics, type in " jd2305 driveshaft replacement"
SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-2PS...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52128)
2003 International...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A51222)
2020 INTERNATIONAL...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A52128)
2023 New Holland...
