JD 2305 Drive Shaft U-Joint = Kabota?
   / JD 2305 Drive Shaft U-Joint = Kabota? #1
Curly69
Henderson County, NC.
2006 JD 2305
I have searched but came up empty. I need u joints for my drive-shaft and understand Kabota has them for their machines and are the same as JD. Unfortunately JD only sells the entire shaft at over $500.00 which I just can not afford at this time. Any help with pt numbers would be helpful.
Thanks.
   / JD 2305 Drive Shaft U-Joint = Kabota? #2
kubota part # 37410-13722 Joint Kit used on JD 2305
   / JD 2305 Drive Shaft U-Joint = Kabota? #4
Does anyone know if the u joints on 2320 are the same as Kubota
   / JD 2305 Drive Shaft U-Joint = Kabota? #5
I have a 2305 ( year 2010 ). About a month ago, I put c410 u joints on both ends. $25 each from NAPA. The gray ting is the zerk in the end cap. I'm able to grease each without any trouble. Each joint came with 4 snap rings. Had to use one of my old ones on each joint to fit around zerk. I also had to take all 4 caps off each joint and grind a 1/16 th off so I could get the snap ring to fit in the grove. ( easier than it sounds). Good luck
   / JD 2305 Drive Shaft U-Joint = Kabota? #6
Pictures?
   / JD 2305 Drive Shaft U-Joint = Kabota? #7
Why didn't you just go to JD and buy new spiders? I had to put new bearing in my u joints a couple years back and had ZERO problem getting the bearings from JD. ---- BUT next time I will consider the NAPA ones with the end zerk, I still cannot get at them dam zerks unless I disassemble the entire tractor!!!!
   / JD 2305 Drive Shaft U-Joint = Kabota? #8
I called JD here in Orlando. It was $49 each. Only JD dealer in town. Plus the wait. I would still have the problem of not being able to grease the zerk while it's on the tractor. I asked on a 2210 driveshaft forum here on TBN if anyone knew the Napa joint part number that would fit. No reply. I went to a store winthe the driveshaft in hand- the c410 fit. ( except for grinding 1/16 th off each post.). I posted pics last month under 2305 driveshaft and how I did it.
I can drop the shaft in ten mins. Maybe 20 mins to install spiders and put back on. I can't tell you how much I love the zerk on the end of the cap. After 5 hours of mowing, I greased both joints with the deck on. Not optional- but can be done.vrs dropping. Best of luck. Bill V
   / JD 2305 Drive Shaft U-Joint = Kabota? #9
Correction, I just went out and looked at box-- it jus says plain 410. On other threads, I seen C410 and PUJ410. I asked what one I should use but got no response. The plain 410 in stock fit so that's what I used.
   / JD 2305 Drive Shaft U-Joint = Kabota? #10
For pics, type in " jd2305 driveshaft replacement"
2024 JOHN DEERE FC20M LOT NUMBER 53 (A53084)
2024 JOHN DEERE...
UNUSED CHERY INDUSTRIAL 20' BI-PARTING IRON GATE (A51248)
UNUSED CHERY...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
2017 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2017 KENWORTH T680...
(2) 300 GALLON POLY TOTES (A51248)
(2) 300 GALLON...
1988 BASSTRACKER 20' PONTOON BOAT (A51247)
1988 BASSTRACKER...
