3-Point Hitch Telescoping Stabilizers
/ Telescoping Stabilizers #21
The point of the stabilizers isn't to expedite hooking anything up but rather to make it safe to use an attachment like a box blade to push safely in reverse.
Sent from my iPhone using TractorByNet
Well darn, I bought mine to make hook ups quicker and easier and they sure do. One of the best mistakes I've ever made. Love them. :laughing:
/ Telescoping Stabilizers #22
Everyone will have to forgive my ignorance - I personally purchased mine to enable me to be safer when pushing with my box blade. The secondary gain I guess then for me is ease of hooking up. Still kind of a rookie here........
/ Telescoping Stabilizers #23
I have a kubota L3200 which have turn buckles on the outside of bars. Anyone have pictures of Marks bars mounted on similar original set up where turn buckles were mounted on the outside of bars.
/ Telescoping Stabilizers #25
I bought a set for my L3400 from Mark. Very nice job, only took a few minutes to install.
/ Telescoping Stabilizers #26
I've got the optional ones from Kubota, optioned when I ordered the tractor. These are the best pics I have of them.
/ Telescoping Stabilizers #29
Talked to Mark this morning ordered a set for my L3200. Very nice person to talk to answered all my questions.
/ Telescoping Stabilizers #32
He has about a four week backlog. Got my order in his list last week
/ Telescoping Stabilizers #35
Thanks......this is probably my next purchase.......I bought the Bxpanded hooks for the FEL bucket.....and just ordered the toolbox from them that mounts to the ROPS
/ Telescoping Stabilizers #36
You can get them directly from Kubota for the L3200/L3800/L3301/L3901 and similar sized tractor. Part # L8430. They were $175 when I bought them. Also available for B models, but I don't have that part #.
/ Telescoping Stabilizers #37
Bought a pair for my BX22...they make installing 3PH implements much easier. At first I was concerned that not having turnbuckles to snug things up would be an issue, but that hasn't been the case. Just don't forget to install the pins before using your implement like I once did...nothing bad happened during a full day of work and it was a chipper!
/ Telescoping Stabilizers #38
I haven't seen one I like and they all set the equipment back some distance.
Worse yet, the one I bought (prematurely) has compatibility issues and won't work with many things I try to mount back there. For starters, the distance between left and right pin locations is hard fixed in the quick-attach adapters and every time I turn around an attachment is too wide or has some other issue. Sorry I bought it.
/ Telescoping Stabilizers #39
Half my gear (usually old craigslist cheap finds) wasn't quick hitch compatible. My welder & plasma cutter quickly remedied that. Sooo worth it to not have to get off the tractor to hitch up.
The day I picked up my tractor, rotary cutter & back blade from the dealer I watched them fight for 10 minutes to get the rotary hitched up. I didn't take it off until my quick hitch came in. Never spent half as long as the dealer did hitching up anything with my quick hitch.
Most new gear is quick hitch compatible. Its usually old stuff you have to worry about.
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
Caterpillar Service Letters from the 1990's (A63117)
Caterpillar...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
Gleaner Variable Speed Header Drive (A63117)
Gleaner Variable...
Location Tampa, FL (A61567)
Location Tampa, FL...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
