Chevy vs Ford for work truck
/ Chevy vs Ford for work truck #1
bdog
Elite Member
Texas
John Deere 6130M
I am looking at buying a 2015 3/4 ton gas 4x4 truck for work. I will not be driving it my employees will so I really don't care a whole lot about ride, features, etc. What I am concerned with is which is more likely to hold up longer and give me less problems.
The truck will be used to pull trailers 5,000 - 10,000lb maybe 1000 miles a month. The rest of the time it will be practically empty shuttling 4 guys back and forth from jobsites and just parked at the jobsites during the day.
Any advice or is it really just a matter of personal preference?
/ Chevy vs Ford for work truck #2
Ford all the way. That is all the towns buy.
/ Chevy vs Ford for work truck #3
No frame issues and no electrical issues.
/ Chevy vs Ford for work truck #4
Why a 3/4 ton for only 10K? Either way both are ok but to me the Ford with its solid front axle is just a tougher setup and comes with a much better transmission.
Chris
/ Chevy vs Ford for work truck #5
Are you buying a chassis cab and adding a flat bed or just a regular crew cab work truck? Really either one would be fine, I know the Chevy's are new (think the super dutys are too but not sure). The 6.0 is stone reliable and been around since forever it seems like. I will say more farmers around here seem to be turning to Ram here in the HD trucks lately for some reason. Not me, if I can't buy a GM I'll just buy a Ford.
/ Chevy vs Ford for work truck #6
Most all trucks are good nowadays..Anyway, you could easily do what you listed with a correctly equipped 1/2 ton. In fact most of the ones sitting on the lot can do it without any great shakes....Might get a better deal on the 3/4 due to the more limited demand though...
/ Chevy vs Ford for work truck #7
I actually went to buy a 2014 2500 HD but got a better deal on a 2014 all new 1/2 ton. The HD was last years model btw. I thought that was odd so I went with the 1/2 ton because it was thousands more off even though the msrp of the two trucks was close.
/ Chevy vs Ford for work truck #8
That is odd..Some of the 1 tons and 3/4's that I looked at had much better deals, I just couldn't do it due to having to park in the occasional city parking garage and the over 1/2 tons are generally too tall.
Chris
We are using it for business and work out of state. Under those conditions if you GVWR is over 10k you must follow all DOT rules like log books hours of service etc. If we keep the truck under the limit we only have to follow the rules when trailers are attached and we are traveling to the jobs and not on a day to day basis while we are there.
/ Chevy vs Ford for work truck #10
I could be wrong, but I think Chris was alluding to modern 1/2 tons being capable (w. certain option packages) of towing 10,000#.
Rgds, D.
Chris
I thought you were suggesting a one ton not a half. I like a lot of safety margin. I would much rather run a truck at half its capacity than at its max. It will last a lot longer.
/ Chevy vs Ford for work truck #12
I am looking at buying a 2015 3/4 ton gas 4x4 truck for work. Any advice or is it really just a matter of personal preference?
Both brands are capable, which one will offer you the better deal?
Not all towns, ours is GMC.
/ Chevy vs Ford for work truck #13
The straight front axle on the Ford/using it snowplowing and being on Maine's bad roads were why I chose the Ford.
Historically anyway the frames, axles, etc were a gauge heavier than others, which always showed in the higher weight & lower fuel efficiency, traded to an extent for durability. 10000# is not much for towing, and if it's good roads, no front axle load, and mainly a commuter, fuel efficiency & ride comfort may count for more to you (?).
For gains made by other companies, statistically Ford is still tops by a large margin in the fleet market.
/ Chevy vs Ford for work truck #15
The company I work for has about 300 trucks on the road. They are all 2008, 2011, 2014 models.
For 1/2 tons we have F150's and Avalanches for the executive staff with some Silverado trucks mixed in.
We have no 3/4 tons but lots of 1 ton SRW. All are GMC diesels. The 08 and 11's have been very good. The 14's are troublesome. He will not hang a plow on a GM truck due to the front suspension.
For all our dullay trucks we are straight Ford. Yesterday I drove a Crew Cab 08 F350 with 181,000 miles. We have F350, F450, and F550's. My boss feels the Ford's are just tougher due to them all using the same Chassis. Each and every one has a Western V-Plow, about 75 units. We have large plowing contracts like FedEx and Amazon hubs in Indianapolis.
Not a single Dodge in the fleet but we do have some Mercedes and BMW cars.
Chris
/ Chevy vs Ford for work truck #16
It seems the Fords up here can't keep the front axle ball joints in them......I'm getting tired of changing them for people.
/ Chevy vs Ford for work truck #17
Since it really is a wash why not get the input from the guys who will be driving it. Make them feel empowered and sounds like the actual decision doesn't matter one way or the other.
I would vote Ford, all the oilfield service companies use them and they get run hard nonstop and still keep on ticking. I had a 2008 F250 Diesel work truck that I put 100,000 miles and 7,000 engine hours on and it still ran good. It did need a set of injectors and the A/C blower went out on me in south Texas (in July!) that truck idled a lot.
/ Chevy vs Ford for work truck #19
What ever you get, an automatic transmission will last longer and present many less problems than a manual. Both manufacturers have good vehicles. Its the way they are handled and the maintenance they receive that determines longevity.
/ Chevy vs Ford for work truck #20
If price for both trucks were close to being the same id start shopping dealers. You're going to have to deal with them for warranty and recall work anyhow. My local Ford dealers are awful, just awful and they've never sold me a truck and probably never will and that has nothing to do with ford trucks. I'm not too hung up on brand loyalty but I am all about a good dealer and the GM people are as good as I'm gonna do around here. They're country people with no fast tricks up their sleeves but they can be slow in the service shop sometimes. So the trade off is honest and slow or get your truck back fast and be shady, what a pickle huh? Shop dealers! You'll thank me later.
