Fittings backing off... suggestions
/ Fittings backing off... suggestions #21
I would try 2 1" flat stock with a hole in the center of each run a bolt with a spacer between the 2 so that the flat stock doesn't bow out. This is after you line the fittings flats inline with each other. A 90 deg open wench might help getting them in line.
Yes, the above is close to what I was going to suggest. You can buy right angle open end wrench adapters, use one on each fitting, put a carriage bolt head through the hole on each wrench end, and fit a plate between each, and use nylock nuts to secure the plate to the two opposite facing wrench end adapters. This way neither fitting can move from where it's set.
/ Fittings backing off... suggestions #22
crows foot wrench.jpgLlaves-_LLAVE_HEXAGONAL_CROW_FOOT_-LLAVE_HEXAGONAL_CROW_FOOT.png
Crowfoot, straight and flare nut
/ Fittings backing off... suggestions #23
/ Fittings backing off... suggestions #24
I was thinking more like this.
/ Fittings backing off... suggestions #25
Drill the nut for safety wire as tcartwi shows and safety wire.
If that scares you , tighten a suitable sized jubilie (hose clamp) around the flare nut until it is misshapen to the hex profile and use that to safety wire in place.
/ Fittings backing off... suggestions #26
How about putting a rubber hose over both nuts, then hose clamps over the hose and nuts.
Drilled one of my spare fittings yesterday as a test. It was allot softer than I was expecting it to be, so that's the way I'm going to go.
/ Fittings backing off... suggestions #28
I have two -16 JIC fittings on a machine that are constantly backing off due to vibration and hydraulic pulsing. Does anyone have a suggestion as to how to lock these down? I've looked at jigs to drill the fittings for safety wire, but the ones I've found only go up to -12. Loctite makes a thread locker just for this, but everything has to be clean and dry to apply it which never happens, particularly under field repair conditions.
What do you say...
I say one hose clamp around both fittings, that would keep them from turning. :thumbsup:
Edit: Too late! :laughing:
/ Fittings backing off... suggestions #29
LOCTITE makes a product for use with hydraulic fittings. There seems to be a lot of issues with Parker JIC fittings backing off from vibration. Can you change out the ports and hose fitting to ORFS? This is a much better seal for vibration applications.
/ Fittings backing off... suggestions #30
Nuts that go on bolts are deformed in various ways to keep them from loosening. You could just smash the nut a little near the end to give it some friction on the threads.
