rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 11,394
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
67F @ 07:00 ... heading to bed here in a few ...
Didn't get much cleaning done last night ... ended up doing a whole bunch of grinding though: the tractor-side SSQA brackets, side plates for the shrub bucket, and parts for the grapple.
The image below is four pieces of 1/4" plate that were cut with the O/A torch from the 4' x 8' sheet of plate. They will serve as the bottom of the masts/towers for the upper jaw of the grapple and as mounting points for the SSQA attachment plate.
Being cut with the torch, the edges were pretty rough and the size varied a good bit ... so I tack welded them together and then ground them, so that they would be fairly close:
They will provide an additional 20 degrees of roll back (my loader only has 26 degrees of rollback) for a total of 46 degrees.
