Pressure testing difficulties
/ Pressure testing difficulties #41
I think I understand whats being said also,
Here's my take on it,,....
hydraulic flow is going through a pipe at a set pressure,
this pipe may have several "relief valves" along it's path,
the one that is set to open at a "lower" relief than the others is called the Master Relief,
the others are just along for the ride.
Now if they are all set "equally" ( to open at a set pressure) The term "Master" would not be used,
since they all are equal in operation.
If there is only one relief valve in the system ( from the factory with no loader etc),,
it can be refereed to as the Master relief valve, BUT, installing another relief valve in series with this
Master valve at a lower relief setting will remove it's title and now become the Master valve.
I hope I got this right,
I also now understand what the "work port reliefs do" and from my gathering on these is...
they are not adjustable.
I also see now , that it is best to set "all" relief valves equally.
/ Pressure testing difficulties #42
Well, actually, some work port reliefs are adjustable.
Here are some adjustable work port reliefs from Prince.
A - NO RELIEF PLUG
B - SHIM ADJUSTABLE RELIEF 500-1350 PSI
C - SHIM ADJUSTABLE RELIEF 1351-1750 PSI
D - SHIM ADJUSTABLE RELIEF 1751-2200 PSI
E - SHIM ADJUSTABLE RELIEF 2201-3000 PSI
F - ADJUSTABLE RELIEF 500-1350 PSI
G - ADJUSTABLE RELIEF 1351-1750 PSI
H - ADJUSTABLE RELIEF 1751-2200 PSI
J - ADJUSTABLE RELIEF 2201-3000 PSI
K - ADJUSTABLE RELIEF 3001-3500
/ Pressure testing difficulties #43
skyhook
What you just stated is WHY I questioned J_J in the very beginning of this thread.
Jim
/ Pressure testing difficulties #44
Like I have said many times.
Use the term if you want but the relevance changes.
Da** This is getting a bit much.
LET IT GO JIM.
/ Pressure testing difficulties #45
LET IT GO JIM.
Let what go? Correct me if I'm wrong IS NOT THIS FORUM CALLED A DISCUSSION FORUM?
/ Pressure testing difficulties #46
But we have beat this thing to death.
You can be the winner, but I don't know what you won.
/ Pressure testing difficulties #47
J_J
I'm not striving to be the winner ! As I've previously stated I think information posted on a tractor discussion forum should be correct information. If you don't realize that some correct and incorrect information has been pointed in this thread then I'm glad I asked my original question.
Have a nice day,Jim
/ Pressure testing difficulties #48
Tx Jim and J_J
I started following this thread because I am having an issue with my Mahindra 3016 Shuttle. I have a FEL and a BH and both of them work completely fine. However, I fabricated a 4 spool remote assembly to completely control the 3pt hitch and that connects to the BH remote QC. Everything works great except until a load is place on the cylinders. I went ahead and hooked a 5K gauge into several points within my new circuit and am only reading about 300-400 psi even at PTO rpm. For the sake of expediency, here are some answers to questions that I presume you would ask:
The FEL and 3pt hitch function the same as ever.
The pressure read when the FEL functions are engaged drops to a point where it does not register
The pressure read when the 3pt hitch is engaged surges up to 2000-2200 psi
Each of the new remotes is controlled by Northman Power Solenoid Directional Control Valves
The solenoids are the closed center type
Any thoughts, advice, or help is greatly appreciated.
/ Pressure testing difficulties #49
One thing leaped out at me and that is, that your tractor is open center hyd system.
Why are you using CC valves.
You should be using open center valves.
3016 4WD Shuttle | Mahindra
As far as reading pressure, it depends where i th eflow path yu put the gage.
If you plug the gage into the 3pt or remotes, and use the loader, the loader will use all the fluid and nothing downstream.
/ Pressure testing difficulties #50
Thanks for the quick reply.
I chose CC valves because my thoughts were that I was simply adding four valves, in parallel, into the interconnection between the P and PB that needed to be maintained when I took the BH off. Seeing as how there should always be flow through that part of the circuit between the P an PB, I didn't think that the CC would be a problem.
As far as where I was inserting the gauge to get the reading, I put the gauge on a tee right after the QC fitting and before the first DCV. If you need a more detailed schematic please let me know.
/ Pressure testing difficulties #51
A CC valves blocks the hyd flow and causes the fluid to pass through a relief valve upstream as most solenoid valves no not have relief valve.
An open center hyd system uses a gear pump to pump fluid and the fluid is always moving.
How long has the valves been installed?
If you need solenoid valves for remotes, then select the open center valves.
If you want to read the pressure for any part of the system, install the gage in a tee in the IN port of the first valve. Then anytime you use a valve, the gage will reflect the pressure developed by that circuit.
However as in the other post about relief valve, the lowest valve relief setting will limit the pressure.
If you remove those CC valves and connect the PB hose from the FEL to the 3pt, you should be back to normal operation.
How long have you had those valves? Maybe Northern will exchange them for you.
/ Pressure testing difficulties #52
JJ, please excuse my ignorance of Hydraulics but I'm wondering why bother having 3 relief valves if the lowest one will open before the others do. I am willing to learn.
/ Pressure testing difficulties #53
You have a lot of post so you must know something.
All hyd circuits need relief valves as the fluid is almost incompressible. You don't want to stop the flow unless you want it to do work.
A gear pump, as in an open center hyd system is pumping all the time, and if you try and stop or block the flow, the pressure will build up until something burst or breaks.
Why three or 4 relief valves in the same tractor,
Every tractor using hyd needs a relief valve, and when the tractor is first made, it usually has one relief designed for the 3pt..
Then someone installs a loader and runs the flow though the FEL first. Well, that valve needs a relief.
Then some one installs a remote valve and it also has a relief.
So now you have three relief valves in the flow path.
Some people like too use the term { Master relief ] but that title will change depend on the setting of which relief.
Logically, you would set all relief valves the same.
You could set each valve to a set pressure to relieve when that hyd circuit developed pressure up to the set pressure.
Now, if the are three relief valves in the series flow path, If you activate the last valve, then the lowest relief setting upstream will activate and protect the total hyd circuit. Also, the lower pressure will limit the force developed by a cyl or motor.
If someone makes a mistake and sets one relief lower that the others, like the 3pt, that relief will relieve only when you are using the 3 pt.
The 3pt relief setting will not affect the remote valve or the FEL valve.
Why you say, because the FEL cyl develops the pressure and if the pressure exceeds the FEL valve relief setting, the fluid will divert to tank. No fluid goes downstream.
So in essence, you have to think a little to know what is actually happening.
You have to know how each valve works, and what it is supposed to do, and how to interpret the indications when it is not working.
You could get by with one relief on the first valve. You can make the FEL relief operate by setting the pressure for the other valves higher than the FEL setting.
That is all I know and I am sticking with my story.
/ Pressure testing difficulties #54
I am a little curious how they told you to connect those valves.
Did they ask you what they were for?
/ Pressure testing difficulties #55
JJ...:thumbsup:
/ Pressure testing difficulties #56
LeeWorm
I agree CC valve on an OC center is a big no-no and vise-verse for OC on a CC center another big no-no.
/ Pressure testing difficulties #57
JJ & Jim,
Thanks for the verbal wrist slap and the input. To answer the question JJ, Northern Tool did not ask what I was hooking up. If you have a moment; take a look at these one line schematics which pretty much depict both the layout as well as the train of thought that went into this.
I chose to go with CC valves because I was under the impression that I would not be truly dead heading any the legs of the circuits as I was providing a continuous path for the pressure being routed through the PB.
If I need to swap out to OC valves will I have to re-plumb the subplates in series or can I keep them in parallel as they are plumbed now?
/ Pressure testing difficulties #58
Also, to answer the question about how long I have had these valves tied into the hydraulics...just a couple of hours which constituted sporadic testing of the functions and pressures. So if the PRV on the FEL is bypassing then it hasn't been for any real extended period of time or prolonged use.
/ Pressure testing difficulties #60
JJ & Jim,
In OC hyd circuits, the flow is in series from pump to tank.
So with all OC valves, the pressure line is the input, and the PB passes fluid to the next valve IN port.
With a three gang subplate, the ports are connected internally, so that on the basic subplate, you have one IN port, a tank port, and work ports for each valve. The pass through fluid for the subplate is through the tank port.
You could call the tank port the PB if you want as it has a 3000 psi + rati
The subplate tank port does not go to reservoir unless it is the last valve in the hyd circuit.
Your hyd circuit should look something like this.
Pump to FEL, PB out to subplate IN port, subplate tank port to 3pt IN port.
If you want a relief valve for the subplate, they do make them with a relief port.
The relief for the solenoid valves is upstream, the lowest setting relief valve in the series flow path.
I recommend sending your CC valves back and exchanging for OC and OC subplates.
New/Unused AGROTK YC-26G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A63688)
2023 Kubota...
2019 Big Tex Gooseneck Low Pro Equipment Trailer (A66285)
2019 Big Tex...
Landhonor Quick Attach Seeder (A66285)
Landhonor Quick...
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A65563)
2008 Kawasaki...
