Protecting against theft
/ Protecting against theft #1
1Lawman
Joaquin, TX
2012 John Deere 5093E
What can I do that would be easy and within reason, to my 5093E that would make it more difficult to steal?
/ Protecting against theft #2
Lock it in a barn, take out the key, install a hidden battery switch.
/ Protecting against theft #3
leave pto on, remove starter fuse, install battery quick disconnect or for real protection remove one of the wheels
/ Protecting against theft #5
You'll never stop pros!
But for joy riders possibly the easiest is to cut the starter relay wire and install a hidden switch in that line.
Another would be hidden switch in your seat safety switch wire. (or even pulling one of the wires off of seat switch)
My tractor safety switch was on the H-N-L selector. The selector switch being defective the wires were linked together to start so my hidden safety is to simply disconnect the mated connectors.
How can I find my starter fuse?
/ Protecting against theft #10
fuse should be marked in fuse box if not keep removing one till it won't crank
/ Protecting against theft #11
You can follow all steps as mentioned, but you won't stop a pro. Get insurance on it if you don't already have it.
/ Protecting against theft #17
IMO the majority of suggestions will deter the typical deviant from taking it for a joy ride but someone intent on stealing a tractor is going to be prepared and just winch it up on a trailer or roll back and be gone...
/ Protecting against theft #18
Pretty much. Pull the key, pull a fuse if you so desire but if someone shows up with a trailer or a rollback with a winch, they will still be able to load it up in 15 mins and be gone.
Insuring it against theft is the only foolproof solution...
Aaron Z
/ Protecting against theft #19
I haven’t heard about it on farm equipment locally but what seems common on construction equipment is a GPS unit connected to a cell phone is hidden in the machine if the machine moves out of a preset area it starts sending a tracking signal to the security firm and the owner gets a phone call to check it out
Very cool!
Kubota SVL 75-2 (A64126)
Kubota SVL 75-2...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
John Deere 7200 6R Planter (A66285)
John Deere 7200 6R...
2013 Infiniti JX35 AWD SUV (A61574)
2013 Infiniti JX35...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
