Pressure testing difficulties
/ Pressure testing difficulties #21
Okay, "gage vs. gauge" notwithstanding, there's clearly some confusion going on here . . . I only have a few active brain cells left, so don't want them all in a tither over this :c).
On my B3350 and BH77 hoe: with the hoe off, there's a "power beyond" hose to plug into a fitting on the tractor, this is part of a series loop, dumping the hydraulic fluid back into the reservoir (if I understand this correctly). Routing this hose through the backhoe doesn't change a thing, as long as no valves are moved on the hoe . . . the fluid simply routes through the hoe and back to the tractor's reservoir, right? When one moves a lever on the hoe, then the fluid gets pressurized as it's diverted into a cylinder to do work. Any relief valve on the hoe itself, will only bypass back into the original hose going to the tractor's reservoir - - it would thus have no bearing on any work (pressure build up) being done by any other hydraulic cylinder on the tractor. A relief valve on the hoe, if set lower than the main relief valve on the tractor, would not bypass before the tractor mounted relief if the hoe was not in operation (i.e. the hoe itself, when not being used, is bypassing all the fluid back to the tractor and thus experiencing no pressure build up to speak of).
If this ain't the case, I'm lost!
bumper
/ Pressure testing difficulties #22
I am not sure of your question, but here goes.
If the BH is connected, the pump flow is directed through all valves in the series path.
Pump ,hyd blk, BH, 3pt, tank.
When any valve is operated, the cyl attached to that circuit is activated, and the cyl expended fluid is sent to tank except is some situations.
If you should only use half lever, some fluid goes to cyl and some fluid goes to the 3pt and then to tank.
All relief flow goes to tank.
If a downstream valve is activated, it will cause back pressure to upstream valves.
If a valve upstream, is activated, most valves downstream will have no flow through the PB port until that valve operation is complete. Again, half lever will allow some fluid to flow.
Looking at your BH, I don't see a valve relief, but I do see 6 work port relief, which dump to tank if cyl pressure is exceeded.
One of the questions earlier was, will the FEL relief operate if using the 3pt, and it can if set lower that the 3pt setting. If both relief are set the same, then either one will operate.
Forget the master relief, the relief valve upstream after the pump is usually in control.
You could set each relief to a different valve to protect that circuit, but if there is a relief upstream set lower, then that relief will activate.
You all have to agree that the lowest relief valve setting in the series flow path is going to operate at the set pressure
For instance, if you had some 2500 psi cyl on an attachment and using the remote valve set at 2450 psi,, and your FEL valve was set at 2950 psi.
The remote valve would operate and protect the cyl when the attachment cyl developed the 2450 psi.
/ Pressure testing difficulties #23
In other words, if my backhoe's relief is set "lower" than the hydraulic block's, it could very well be the reason
my loader is going into relief before it should while the hoe is attached..:confused:
Whats your theory on this, JJ.
/ Pressure testing difficulties #24
If your BH seems weaker, then it is because it is due to the relief set point or the valve is leaking.
If your loader valve is set to say 2500 psi, and that is the only relief before the 3pt, then the loader valve relief will dictate the relief pressure.
If your BH has a valve relief set higher that the loader, the loader will still dictate the relief pressure.
If your BH has a valve relief and is set lower that the loader relief, then the BH relief will dictate the relief pressure.
The relief valve with the weakest setting upstream will activate first.
As you use valves further downstream, the valve with the weakest relief valve will activate.
/ Pressure testing difficulties #25
J_J
OK on my '11 Kubota M7040 with a Kubota LA1353S FEL the feedback rod was set incorrectly so as when the 3 pt was fully raised the 3 pt continued trying to raise. The relieve valve that opened was the 3 pt relief valve not the factory FEL relief valve. No I did not install a "gauge" but used a laser thermometer to determine the heat differentiation plus the sound of the by-passing valve. I wouldn't alter my tractor's factory set relief valves while tractor is in warranty anyway. After adjusting feedback rod noise and heat at rear of tractor disappeared.. Are you trying to state that on a Kubota tractor that FEL relief valve should come from factory set at a lower setting than 3 pt relief valve.?????????????? If the books don't mention MASTER RELIEF then this wild idea must be YOUR THEORY !!!!!!!!!! Did you ever research the differences in CC & CCLS hyd's?
Jim
If your 3pt valve is set lower than the loader relief valve, then the 3pt will definitely relieve.
When you see tractor specs for the tractor with out attachments, usually the only relief is the 3pt.
How the loader valve is set is debatable.
They probably set what ever the attachment manual calls for. If it should be lower than the 3pt relief, then the loader relief will dictate the max pressure, and not the 3pt.
So if you want max pressure out of the hyd system, set them the same.
So when checking pressure, you have to know what you are doing and how things work.
If you are smart, you would set the loader relief to tractor specs and then go down the flow path setting all relief valve the same, including the BH if it has a relief.
Only then will you be getting max pressure out of all valves.
Work port relief are different.
/ Pressure testing difficulties #26
J.J.
Just to be clear, the work port relief/s on my BH77 don't provide relief function for anything other than the backhoe function/s (valves) that have them. When they go into relief, they start bypassing the BH cylinder/s doing work and send the bypassed fluid to the tractor reservoir. The BH work port relief/s do not affect other tractor functions such as the FEL or 3-point. However, a tractor relief port would affect the BH *if* it is set at a lower pressure than the BH work relief ports - in which case the BH work port relief port would never bypass as the tractor's relief port would bypass first, thus limiting the power available at the hoe.
Right?
bumper
/ Pressure testing difficulties #27
I think I'm starting to understand how this work's now,,
whats the difference between "relief ports" and "Work port relief's".:confused:
/ Pressure testing difficulties #28
J_J
My M7040 has performed any hyd task I've asked it to do therefore I will be SMART and leave all relief valves set exactly the way they came from the factory.
Again I'll ask if the tech manuals don't mention "master relief valve" then why do you call FEL a master relief valve when in fact you admitted that the valve set for lower psi will pop off 1st which anyone who understands hyd's know this is a fact. ??????
PS: Skyhook has a good question whats the difference between "relief ports" and "Work port relief's"
I hope you have a good day,Jim
/ Pressure testing difficulties #29
My day is going good. I love this stuff
With valve lever in neutral, work port relief protect against cyl over pressure.
While cyl's are being pressurized, the valve relief protect the circuit and pmp, whether that valves relief or a relief valve upstream set lower.
A relief port/aux port is the port where a relief valve would fit.
A work port relief will usually work when mechanical work forces a cyl to exceed the set pressure.
An example would be when you slide a load off a trailer, and place the lever in neutral and the load exceeds the cyl potential. The work port relief will release the pressure to tank dropping the load to the ground. The main relief is not in use with valve in neutral.
The term Master relief can be associated with the relief valve that is doing the most work.
If you want to use master relief, then do so to indicate that relief valve in charge.
I really don't care if your/all manuals says master relief, but if there is another valve relief doing all the work, why call the other relief valve the master relief.
The valve relief doing most all the work is also called the Main relief, and that will change if you want it to which valve relief is set lower..
Some of you are grasping at inference.
Inference: Deriving Conclusions from Indications
/ Pressure testing difficulties #30
While cyl's are being pressurized, the valve relief protect the circuit, whether that valves relief or a relief valve upstream set lower.
What's a main relief? Is that a different terminology for master relief?
/ Pressure testing difficulties #31
J_J
If a manual does mention master relief or main relief valve for that moment in time, it may be temporary, but if you add another valve with the relief valve set lower upstream, the other relief is not the master, the lower setting relief is the Main relief for the total open center hyd system.
Jim, I respect your intelligence, but don't even try to insult mine.
I do have some knowledge that I gladly share.
/ Pressure testing difficulties #32
Only use the term, master relief if you know how the term is used.
ARE WE FINISHED YET?
/ Pressure testing difficulties #33
J_J
If asking you to explain/clarify one of your statements is insulting you so be it!! Now your stating the main relief is the relief valve with the lower psi setting which could or could not be the FEL valve that you allured to when I 1st questioned your Master relief valve statement. All I'm trying to do is insure that information posted on tractor discussion forums is CORRECT information.
Jim
/ Pressure testing difficulties #34
I don't know why you persist, but here goes.
If the first valve in the pump flow path has a relief setting lower that the other relief valves, then it is the main relief. Even call it the master relief if you want.
If say a remote valve has a 2500 psi setting, and the FEL has a 2700 psi setting, and the 3pt has a 2600 psi setting, which valve will limit the 3pt pressure. The remote relief valve.
In this situation, the FEL will relieve at 2600 psi.
If you use the remote valve, that circuit will relieve at 2500 psi.
If you use the 3pt, it will relieve at 2500 psi, why, because the remote valve sets the pressure downstream.
So, if your tractor came from the factory set at say 2500 psi on the 3pt, and whoever installed the FEL set that valve to 2450 psi, then your FEL valve will limit the pressure to 2450, and you would lose some potential on the 3pt.
Take a look in your tractor and FEL manual and tell me the relief settings, and I will give try and to give you an answer as to how and why.
The logic would to protect the hyd circuit.
Also think of this. Does the 3PT cyl have a better pressure rating than the FEL cyl?
It depends on the relief valve setting as to which valve relief will relieve.
/ Pressure testing difficulties #35
Because power beyond is blocked off during any FEL valve operation correct?
Thanks JJ, very informative as usual. NOT to change the subject but often times when my FEL will not quite lift the load I am trying but if I run the tractor WIDE OPEN (2950 RPM) the FEL will lift the load. I am guessing because the relief valve cannot handle the volume of oil asked to go through it?
Regards, Fred
/ Pressure testing difficulties #36
The answer is that when operating the FEL, the FEL valve is the only valve using the fluid and the cyl expended fluid flows through the OUT port. The other valves downstream don't have enough fluid to do anything.
However there are some valves that will pass cyl expended to the PB flow path.
/ Pressure testing difficulties #37
J_J
You're the one that initially called the FEL valve the "Master valve" which is what caused me a question you.
Good day,Jim
/ Pressure testing difficulties #38
(( In this situation, the FEL will relieve at 2600 psi.
Thanks JJ, very informative as usual. NOT to change the subject but often times when my FEL will not quite lift the load I am trying but if I run the tractor WIDE OPEN (2950 RPM) the FEL will lift the load. I am guessing because the relief valve cannot handle the volume of oil asked to go through it?))
The relief better be able to handle all flow the system will see or something may break.
/ Pressure testing difficulties #39
Wow, I believe I have explained everything about that in detail.
Call it a relief valve, main relief valve or master relief valve. You should be able to relate to the use of the terms.
It's no big thing, just saying
/ Pressure testing difficulties #40
I didn't see it resolved in the prior posts but gage and gauge have been used interchangeably for eons. It's like colour and color, harbor and harbour. The best dictionaries will explain they are just spelling variations, neither one incorrect. In the case of gage and gauge it is not British and American versions - it's just however you want yo spell it. I like gauge myself because the word is longer, seems like more precise like a gauge should be.
On the minor part of the question, unless closing the valve prevents oil from getting to a relief, the lowest set relief controls an open circuit just like I think JJ is trying to say.
Lincoln Electric Shield-Arc SAE-400 DC Welder - Engine Driven - Radiator Missing (A63689)
Lincoln Electric...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
New/Unused CFG Industrial MX12RX Mini Excavator (A65579)
New/Unused CFG...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
