Briggs v twin weird starting issue
/ Briggs v twin weird starting issue #1
pickeringchris
Gold Member
Alright folks. I am perplexed and I know you will be too.
Battery charged. 12.6v.
Brand new starter.
Turn key to start, solenoid does a rapid clicking, starter does not move
Ran brand new main ground and solenoid ground.
Trigger to solenoid gets voltage when key is turned.
Solenoid gets voltage on both sides when key is turned.
Here is the good part. If I put my multimeter directly on the battery +/- and turn the key, the motor starts. Every time. Lol.
Ideas?
Thanks so much.
/ Briggs v twin weird starting issue #2
Loose battery terminal. When you put your meter leads on the terminals you are making the connection better.
Negative. Wire brushed terminals and clamps. Clamped tight as ****.
/ Briggs v twin weird starting issue #4
Broken battery terminal inside the battery. When you push on it you make the connection better. Had the same issue in a Pontiac I owned, took me forever to figure it out.
Trust me. This is 100% not the case. Battery is fine. I've tried it a dozen times. Attach multimeter it starts. Remove multimeter it doesn't.
I'm gonna do a vid tomorrow. You guys will believe me then ;-)
/ Briggs v twin weird starting issue #7
It only takes one of the following questions to be overlooked. #1 battery connections, clean and tight, no corrosion at terminals where they make connection to the copper wire. At the battery, solenoid, and starter. This is where I suspect the problem lies because your volt meter leads may be touching the post and the cable lug to make a better connection, and that's why it starts when you test at the battery. The clicking noise is usually low voltage to the trigger on the solenoid. #2 Do your grounds connect to the engine BLOCK, not some piece of sheet metal that bolts to the block, both from the battery and the solenoid, preferably to the same lug on the engine block. If your battery has a short wire that grounds to the chassis, run a #6 ground wire from the battery directly to the block. #3 What are your voltages at the trigger and both sides of the solenoid, they should be 12.6v in your case. With the starter not turning, but in the start position (key) do you have 12.6 to the positive BOLT on the starter. testing the bolt, not the cable lug will eliminate another path of resistance. If 12.6 here bad ground where starter bolts to block, or an intermittent open in your new starter. Lets not go there yet. If the trigger is less than 12v I'd suspect a bad safety interlock switch/connection causing high resistance/low voltage. After you have checked ALL of these things, I would bypass the entire OPC (operator presence control) or safety switch circuit. Set the brake, make sure blades are disengaged, and the transmission is in neutral. Use a start switch, 2 wires hooked to a push button switch with alligator clips on the ends (best), or a screwdriver to make a circuit between the trigger and the battery side of the start solenoid. Enough for now, let us know the outcome, and we'll go from there. I assume this is a lawn tractor/mower with the Briggs V twin OHV, but if not all still applies. I don't know electrical, I have spent most of my life learning it! As "Astro" the dog on the Jetrsons cartoon used to say, Rots of ruck! 445A
/ Briggs v twin weird starting issue #8
Quicksandfarmer: That's where I was going next, good call. A GOOD set of jumper cables will diagnose that quickly! 445A
/ Briggs v twin weird starting issue #10
Unreal! Do me a favor, try this: Take a good heavy duty pair of jumper cables and hook them to the battery, but leave the other ends open. Now try to start. If no start clip the other end to your volt meter and try to start. If it starts without the volt meter it's a bad connection at or INSIDE the battery. If it starts with the meter... You must have one mean battery in that volt meter! My idea here is to isolate the problem by not moving the cables at the battery. I am curious if you hooked the VM to the eng. block and positive at the solenoid, would it start. You will need someone to help cause your VM doesn't have clips. I love these kind of problems and will be going over it all day in my head. Check you back later. 445A
Thanks so much for your help so far. I was up till 2am trying to figure this out but didn't get any further. Today Im working on something then going away for the weekend. I may not get back to it until monday. I can tell you one thing, it's eating me up inside. Lol
/ Briggs v twin weird starting issue #12
What happens if you leave the probes from the voltmeter attached but disconnect them at the voltmeter?
What happens if only one probe is attached?
Watching your video, I still think it is the physical action of the VM probes against the battery terminals.
/ Briggs v twin weird starting issue #13
The battery alone does not have enough amps to engage the solenoid. The meter gives it enough thru the meter's battery. Change the solenoid or change the battery. I think you got a battery going bad. Try a different battery.
hugs, Brandi
/ Briggs v twin weird starting issue #14
I forgot to put a:laughing: at the end of this statement. " you must have one mean battery in that volt meter"! I really don't believe any VM can supply enough amps to make a difference. I really do want to get to the root of this problem. 445A
/ Briggs v twin weird starting issue #15
My guess is a badd connection also. Not the terminal to battery but the wire cable to terminal. Corrosion in the wire at the terminal.
/ Briggs v twin weird starting issue #16
Pickeringchris: Well here it is almost a month later, so what have you found? Hope to hear back from you! 445A
/ Briggs v twin weird starting issue #18
I think he has been kidnapped by the pallet people. Last post was 10-10-2014
