200cx mount geometry
/ 200cx mount geometry #1
project_X
Gold Member
Ottawa, ON, Canada
Kubota L235DT and L225
Hi all, I happen to be an Orange tractor owner that needs a loader. Since my tractor is a vintage 1980s L235dt, I needed to fab my own mounts. I came across a cheap 200cx with 2305 mounts.
Could someone measure the outside width of the vertical arms of the mounts and the height to the ground to the top round mount feature.
Thanks,
Rob
/ 200cx mount geometry #2
You have found a Deere FEL and looking for info to mount it to an Orange tractor, it appears. Should be a good fit if you can get the mounts right.
Depending on the height the mounts need to be, I may actually be reasonably easy to fab the mounts. I will put a thread together on the build once I get going.
If someone could make this measurement, it would be a big help.
Could someone measure the outside width of the vertical arms of the mounts and the height to the ground to the top round mount feature? As well as distance from the back of the mast to the tractor front most point
Thanks,
Rob
/ 200cx mount geometry #5
Rob if I can find some free time today I will try to get you this info but first I need to make sure I understand what you need. You want outside width from one vertical arm to the other arm? The other measurement I think I understand.
Exactly
I want to be able to design a mount for my Kubota using the 2305 mounts I have and need the dimensions to ensure they are in the same spot as on a John Deere
Width of vertical arms
Top of uppermost round mounting feature.
Bottom of horizontal tube
And distance from front of tractor.
Thank you,
Rob
/ 200cx mount geometry #7
Overall width is the same as the width of the loader arms 43''. Iphone pics 083.jpg Top of uppermost round mounting is 28'' to the ground. Iphone pics 087.jpg Bottom of horizontal tube to the ground 12''. Iphone pics 089.jpg Distance from front of vertical arm to the front of the bumper 29''. Iphone pics 091.jpg Iphone pics 096.jpg Hope this will help. Henri
Overall width is the same as the width of the loader arms 43''. View attachment 393864 Top of uppermost round mounting is 28'' to the ground. View attachment 393868 Bottom of horizontal tube to the ground 12''. View attachment 393871 Distance from front of vertical arm to the front of the bumper 29''. View attachment 393874 View attachment 393875 Hope this will help. Henri
Henri, Out of curiosity, what model of tractor do you have?
Thanks,
Rob
/ 200cx mount geometry #10
2305, it's in my signature. :thumbsup:
If anyone can help, I need one more measurement before I can finish my mounts. I need the width of the vertical plate for the mount. Outside of the plate at the top and bottom, I think the humber should be about 40". But would like another measurement..
Thanks,
Rob
/ 200cx mount geometry #12
I will try to get that info for you sometime today.
1997 Ford F-350 Service Truck, VIN # 1FDKF38F6VEA38713 (A61165)
1997 Ford F-350...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2R FALLING PLOW (A62131)
2R FALLING PLOW...
UNUSED CFG INDUSTRIAL NT18K MINI EXCAVATOR (A62130)
UNUSED CFG...
2021 CATERPILLAR 301.7CR EXCAVATOR (A62129)
2021 CATERPILLAR...
2020 BOBCAT MT55 STAND ON SKID STEER (A63276)
2020 BOBCAT MT55...
