How strong is my wooden bridge?
/ How strong is my wooden bridge? #41
If you want an opinion on culverts I will give you mine. I have 2 culverts side by side, about 30 inches or so each. They are a pain in the "rear" to keep them from stopping up with sticks, then leaves, then mud, etc. and the water backs up , and I have seen it 12 foot deep, and runs over the road and erodes the other side. I had to buy a bunch more fill to go on the downhill side when I neglected to keep the sticks and muck cleaned out. It is at least a yearly job if not more depending on how much rain we have. I would much rather have one single larger culvert than the twin culverts, as the problem always start with a single stick across the inside edges where they are tangent and goes badly as the stick captures more sticks, then leaves etc. Not to mention the children s floating toys from the housing development upstream. I had no say in the culvert placing, they were there when I came, but I learned the hard way about the cleaning needed. For me it would be one large culvert.
I would go one step further. I would rather have a clear span bridge than even a single culvert much less a double culvert.
/ How strong is my wooden bridge? #42
Yes, that would be ideal.
well said Jim, thank you. I think really I'm going to need to tend to it yearly no matter what
At least I won't have rolling rocks get in there, it's pretty sandy here but there are pockets of clay, and a mix of that is
the area underneath the bridge. Actually fairly clean down there thank goodness.
And no hissing sounds...
/ How strong is my wooden bridge? #44
Thats good, and keep in mind I live in the woods, so sticks and leaves are par for the course.. You may not have as much problem as your drainage might be better...
one thing that has to be attended to sooner vs later is the attachment to that tree. Did they not understand that trees grow upward?...it's pulled the railing up several inches and I sure wouldn't want to lean on it. Pretty rickety actually.
Is there such a thing as pre-made bridges? And I don't mean from Amazon...hah, I'm a Prime member, send me my bridge with free freight please...
/ How strong is my wooden bridge? #46
The pictures in the OPs post show a depth of maybe 4', not 12'. Its a very different situation than yours, which sounds like very undersized culverts for such a potentially high dam if they get plugged. Sounds scary.
Newbury, finally read through part of that bridge manual. Wow...even found a section on how to splice a beam
using a fish plate. I wonder how many folk know what a fish plate is. Might have a newer name...
that manual is enormous.
I think the ditch depth down stream of the bridge is five feet and upstream six feet. I'm guessing by the size of the trees it's been at least twenty years since this ditch was done professionally. Now it looks like an earth science lesson. Lot of erosion.
/ How strong is my wooden bridge? #49
I've helped build wooden bridges on twp roads (many yrs ago). We used rough cut 2x12 oak as joists, double or triple under the main tire track area. Then nail oak 2x? across them for the decking. These were for small bridges the size of yours. We would drive nails with sledge hammers, sometimes drilling holes first for the nails. I know we took dump trucks across these wooden bridges. We also built them with steel I beams under the track area, then nail pt 2x4s on end across for decking, using metal clips that clip on the edge of the Ibeam, nailed to the wood.
I've got a small creek that I'd like to put a bridge across, but since I have a county road next to me, I just drive out on the road, cross their culvert across the creek, then enter my land again. Not worth it to build my own bridge. This little creek is always got running water, fed from "7 springs farm" on the other side of the road. my neighbor on the other side put a culvert across the creek, probably 24 or 30", and it has held up well with some heavy rains. Back on dad's farm we have a few farm roads thru creeks. Course we also have public roads thru creeks, here's one on a public twp road I went thru last year, water was almost a foot deep.
/ How strong is my wooden bridge? #50
It can be. it has the potential to wash the whole road out if you let it go..It takes a big long sustained rain to get to that point, but if you don't clean them out at least once a year, it can happen.
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
4022CFL (A59228)
4022CFL (A59228)
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
