Hydraulic valve leak
/ Hydraulic valve leak #1
matoyan
Rhode Island
kubota b1750, b7100 hst, b2150 hst
I bought a used brantly backhoe and the hydraulic control valves are leaking. how would I take it apart so that I can replace the o-rings? I took it off of the loader and disconnected all hydraulic hoses. Do I just unscrew the bottom and push the rods through?
IMG_3826.jpgIMG_3827.jpgIMG_3828.jpgIMG_3829.jpgIMG_3830.JPGIMG_3831.jpgIMG_3832.jpgIMG_3833.jpg
/ Hydraulic valve leak #2
Is the valve leaking from the spool or the stacked sections?
The part where the handle gets connected to. I'm guessing that's the spool? It definitely doesn't leak from where each section is connected to each other.
/ Hydraulic valve leak #4
Some valve spools have o-rings that can be replaced.
Remove the cans from the bottom of each spool that is leaking and remove the parts on the end of the spool.
Remove the lever and push the spool out and repair.
J.J.
How hard should it be to remove the spool? I took the can off and tried pushing the spool through and it sort of was hard so I stopped.
/ Hydraulic valve leak #6
Did you take all the parts off the spool?
It should slide out.
I installed the o-rings and the valve is working great. Thanks J.J.
LOOK! (A65640)
LOOK! (A65640)
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
SDLOOL SL36C (A64912)
2025 Pabreak 78in Rock Bucket Skid Steer Attachment (A66734)
2025 Pabreak 78in...
2021 JOHN DEERE 304L WHEEL LOADER (A65056)
2021 JOHN DEERE...
2005 Ford F-450 Crane Service Truck (A66736)
2005 Ford F-450...
