Hydraulic valve leak
/ Hydraulic valve leak #1
matoyan
Rhode Island
kubota b1750, b7100 hst, b2150 hst
I bought a used brantly backhoe and the hydraulic control valves are leaking. how would I take it apart so that I can replace the o-rings? I took it off of the loader and disconnected all hydraulic hoses. Do I just unscrew the bottom and push the rods through?
IMG_3826.jpgIMG_3827.jpgIMG_3828.jpgIMG_3829.jpgIMG_3830.JPGIMG_3831.jpgIMG_3832.jpgIMG_3833.jpg
/ Hydraulic valve leak #2
Is the valve leaking from the spool or the stacked sections?
The part where the handle gets connected to. I'm guessing that's the spool? It definitely doesn't leak from where each section is connected to each other.
/ Hydraulic valve leak #4
Some valve spools have o-rings that can be replaced.
Remove the cans from the bottom of each spool that is leaking and remove the parts on the end of the spool.
Remove the lever and push the spool out and repair.
J.J.
How hard should it be to remove the spool? I took the can off and tried pushing the spool through and it sort of was hard so I stopped.
/ Hydraulic valve leak #6
Did you take all the parts off the spool?
It should slide out.
I installed the o-rings and the valve is working great. Thanks J.J.
INDUSTRIAL GOLD 133 GALLON COMPRESSOR (A67714)
INDUSTRIAL GOLD...
2018 CHEVROLET 3500 SILVERADO CREW CAB PICKUP TRUCK (A66091)
2018 CHEVROLET...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
