backhoe woe
/ backhoe woe #1
mikim
Paige Texas
NH TC45
I have a woods 80X hoe on a NH TC45... I've had it about 7 years with no troubles til now. I was digging a trench - put no undue stress on it that I can think of...But the swing left has stopped working. I can swing right under control, but when I swing left it does so out of control and without any torque. Obviously the problem is with the 2 cylinders that do that operation. There are no leaks, and nothing is bent, broken, warped, etc. What can be the problem? Seals inside a cylinder? Which? Is there an easy fix? Getting these things off looks to be a bit of a problem. Once off, how do I determine which one needs repair? My knowledge of hydraulics is limited to "plug this thingy into that thingy and it works" and when it dun't - I'm dun. I took it off the tractor but can put it back on to troubleshoot if need be.
/ backhoe woe #2
You should be able to isolate which cyl is bad by removing the hoses from each and pressurize each cyl to determine which cyl is bypassing fluid.
You could fully extend one of the cyl and and remove the rod end hose and see if fluid can be pushed past the seals.
/ backhoe woe
OK ...I kinda get that ...separate 'em and operate one at a time. The bad one won't work. To remove one I have to remove both ...the way they're mounted...Maybe I'll rig some hose off my log splitter to work these cylinders on the bench.
/ backhoe woe #4
Mike,
You say they need to be removed together? Can you swing the bh boom to the right, take the nut off of the left swing rod end bolt at the boom, then swing the boom back to center, remove the bolt, then swing the boom back to the right. When I do this to mine, I have room to remove the gland nut with the rod and rod end. If you can do this, I can't see taking the cylinders completely off of the backhoe. Then you can replace the o ring and wiper ring that is making it bypass internally. My guess is the left swing cylinder.
hugs<<><><>>Brandi
/ backhoe woe #5
My guess ,on a rainy sat afternoon, is that the piston came off the rod on the left cylinder. If you do the work yourself ,when you get a seal kit get a new nut as well.
/ backhoe woe
Brandi -- You're saying repair the cylinder in place? ... I guess I could try that...the rod end is mounted to the boom with a large drive pin that is held in place with a small drive pin...it might depend on if I can get the clearance I need to drive out that small one. THEN I'd be looking at the cylinder thinking ....gee wonder what's in that thing? I'm going out now to spend the afternoon on a mower...so this whole thing will have to wait til I can get tuit. I have no pressing projects for it so there's no hurry. Thanks everyone for your input. Got a serious hydraulic dummy here. neighbor asked if it could be a valve stuck open? opinions?
/ backhoe woe #7
Mike,
Either I will be going to Manor next weekend, or Rebecca and Chloe will be visiting me. If I go, I'll stop by and give you some words of wisdom. Looking at it will say a lot about being repaired on or off the bh. I do stand corrected. Mine doesn't have a nut either, just a pin with a flange held in place with a small bolt.
Can you take photos and post here? One looking straight down with the bh centered and one with the bh far right. Some from the sides and at angles.
Could be a loose nut. I never saw a nut come off. But I sure have seen trashed piston o rings and backup/wiper rings.
hugs<<><><>>Brandi
/ backhoe woe
Mike,
hugs<<><><>>Brandi
OK -- you just gave me another "honey do" ....I got one woman doing that to me....really need another???? ;)...I'll have to wash it first then take pics. Next weekend - we'll be gone on saturday but should be home sun & mon. I think I have enough to keep me busy at least 1 week without needing the hoe... The biggest problem with putting it on the tractor to work on it - is then can I get it off to do other stuff? Probably.....as I think about it....
/ backhoe woe #9
hydraulic dummy here. just wondering, if you checked your hyd oil levels, and if it ever got low? wondering if there is some trapped air in the hyd cylinders. or at least one of them. and needing to work it out.
are the swing cylinders, double acting hyd cylinders or single acting hydraulic cylinders?
double acting = 2 hoses come off of each hyd cylinder. (3 hoses total, 2 hoses goto a valve, 1 hose connects both cylinders together)
single acting = 1 hose coming off, (2 hoses total).
have you double checked the linkages between valve and lever / joystick. to make sure they are adjusted correctly / tightened?
no idea what valve the swing uses. just wondering if there may be a problem at the valve, such as a spring? or relief valve? that either has gone bad or is getting stuck open/closed?
condoms, of all things, can be easy way to place on end of hoses, and like, to keep dirt and crud getting into things as you disconnect stuff to get in were ya need to get to. some rubber bands, or twisty ties (bread ties) or even zip ties can be used to secure the condoms.
single finger glove (condom for a finger) band-aid isle / area of local stores. can also work. might be a tad easier, for the short stubs / male threads on the valves. after you take the hoses off.
"line wrenches" you have your normal U and O shape box end wrenches, that ya see at every tool store, but then you have "line wrenches" that are more of a C shape, they slip over the hyd hoses, and then slide onto the nuts. it gives you a bit more gripping on the end of the hoses, without wrench slipping off.
--other words a "line wrench" is mix between a U and O shape box end wrench
be extra careful, you will be letting air into the backhoe system, and stuff will not hold at all, make sure you let everything rest down on the ground and pressure taken off of everything, before ya get in there.
if you end up dismantling a hyd cylinder, be careful, the piston/rod could suddenly come loose and shoot out. make sure you stand off to the side as ya work on them. a lot of risk comes from compressed air. but still a risk factor without compressed air, due to overall weight, and how awkward it is to grab a hold of some of the items.
/ backhoe woe
Today's plans got sidetracked so I figgered I'd try to see if I could get a handle on this thing. I put the hoe on the tractor then removed the pins holding the ends of the swing rods on, (pic1) then started the tractor thinking I would then move the stick back and forth and see which one wasn't moving....BUT as soon as I started the tractor I heard woosh - rattle rattle..one of the rods came flying out of it's cylinder volunteering to be the bad one. I got less than a gallon of fluid spilled before I cut the motor. You'll notice (pic2) that it has a bit of curvature and the threads on the end are stripped.....easy enough to figger I need a whole new assembly. Took the whole thing off the hoe (pic3) they are trapped via top and bottom bushings between the blue frame and a black cross member. Hope I can get them torqued back on as tight as the bolts were. I had to use a breaker bar and cheater to break the nuts loose. Guess I won't be able to over torque 'em leaving off the cheater. Being as incompetent a mechanic as I am ... I'm pretty proud of myself getting this far. Course it helped that the errant cylinder jumped out at me. Now all I gotta do is order a new swing cylinder and switch it out..in the meantime the hoe is in the middle of my shop on blocks....oh well.
/ backhoe woe
Not having very satisfying results searching online for this cylinder. Guess I'll call Messicks in the a.m.......est. $300....WOW!
/ backhoe woe #12
consider yourself lucky you don't have an older Case hoe - replacement cylinders for mine, If I could even find one, run $700 to $1000. At that price, if I ever need more than a seal kit there'll be a machine shop involved :rolleyes:
Good job having a hoe that "self-diagnoses"... :D Steve
/ backhoe woe #13
Mike,
Isn't it nice when the system does the hard trouble shooting for you. 6sunset6 was so right on this. I am glad to see you have the project under control. Rebecca will be coming here next weekend, so I will not be flying by Paige.
From looking at your photos, I see all kinds of room around those cylinders. Mine is so tight with the swing lock control rod coming down from the top. Yours has the room of a 6 cylinder engine in a pickup. Mine has the room of a V-12 packed in under a corvette hood.
hugs<<><><>>Brandi
/ backhoe woe #14
Woods might buy cylinders from some other manufacturer. The rod is obviously bent, but you might try a local cylinder repair/hydraulics shop to ask if its a common size or something they can straighten.
/ backhoe woe #15
I agree with 2many. Take it to a hyd. shop before replacing.
hugs<<><><>>Brandi
/ backhoe woe
Brandi---which hyd shop in Paige would you recommend? :rolleyes: My thought is by the time I found one in Austin that could help me - using the old cylinder - it would likely cost me as much as just ordering a new one and having it delivered to my door. Driving from here to Austin and around is a $40 bill to start with. Because of the bushing mount just any 'ol cylinder won't do.
/ backhoe woe #17
If the cylinder isn't damaged or all scorn up I don't see why you'd have to replace it. They would likely just remake the rod if that's the extent of the issue.
/ backhoe woe
But at what cost? and it will need a new piston as well. The threads that are stripped screw into it. and again-- I'm not local to anywhere that has a shop....Austin would be the closest and no guarantee they even have that kind of shop. A lot of industrial work goes to Houston. Austin is all govt and academia and tech.
/ backhoe woe #19
You might be surprised.
Few years ago I had a badly scored FEL tilt cylinder shaft so I removed it thinking maybe polish and re-chrome.
When I picked up the cylinder the shop has re-welded the cross sleeve, machined a complete new shaft assembled with all new seals etc and even changed the short hose assy. Price was about $150.
Friend just last week blew the end off of his Kubota 7100 tilt cylinder.
A local hydraulic shop custom built up an exact replacement for $300.
From your pics it looks to me as a shaft and kit is all you need.
Check around for a hydraulic shop that has machining capabilities. From observation I think any serious shop has no choice but to have at minimum welding and lathe capabilities plus an inventory of ends, shafting and DOM stock.
/ backhoe woe
OK --- y'all talked me right into it...I'll find a shop in Austin and at the very least take it in for an estimate. I have to go in for my hearing aid sometime this week anyway.....hate big cities...
2000 Ford Windstar Van (A64557)
2000 Ford Windstar...
2011 New Holland HT154 Rake (A63688)
2011 New Holland...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
2018 Chevrolet Trax SUV (A59231)
2018 Chevrolet...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A63688)
2022 Schulte...
