NEW YM336D PROBLEM
/ NEW YM336D PROBLEM #1
R Barger
Gold Member
Gate City, Va
YANMAR YM336D/W Loader JOHN DEERE 850/ W Loader 2WD&4WD Kubota RTV X900 Mahindra 4540 4WD w/Loader
It seems like I fix one problem and another pops up.I got the front drive axle and the tractor seemed fine so I mowed with about 6 hours and the tractor quit pulling in the high range. Does anyone have an idea if that would be the main clutch or the power shift clutch pack?
/ NEW YM336D PROBLEM #2
don't know the answer ,but have you checked your hyd fluid level , cleaned the screen
/ NEW YM336D PROBLEM #3
"quit pulling in the high range"
Exactly what does that mean?
The hydrotrans fluid and screen had just been changed when I bought the tractor. Fluid looks new and is full. When you put it 4th gear it will pull on level ground but if you put the least bit of load on it it slips. In the lower gears it seems to be ok. I'm going to check today when the tractor is cold and see if it makes any difference.
/ NEW YM336D PROBLEM #5
Could be the transmission but my first suspicion would be the clutch. If your able to load the pto and see if it slips that might prove or disprove. Or maybe you could notice if the pto slows when the tractor slows. Transmission and pto go through the clutch.
/ NEW YM336D PROBLEM #6
Classic symptoms of a slipping clutch. Start by verifying that the pedal linkage has some slack when your foot isn't on the pedal.
The adjustment was the first thing I checked. I will load the pto and reply the results later. Thanks for the idea's.
The pto still worked when the tractor stopped pulling. Bad news. The low ranges seem strong . better at high rpms. Think it could be the power shift pump? The lift and the power steering work fine so I didn't think it woul be the screen.
/ NEW YM336D PROBLEM #9
If pto continues with tractor stalled out then it has to be in the powershift components. Could be numerous things. I will quote the 226 power shift trouble shooting for: POWER SHIFT TRANSMISSION TROUBLE SHOOTING. Tractor does not move whe power shift lever in a certain speed position: 1. Main relief valve pressure is too high. 2. Main relief valve stuck or its pilot hoe plugged, or wrong spring or shims installed. Solution. Check main relief valve, springs and adjusting shims.
Figure your 336 is about the same as far as how it works.
/ NEW YM336D PROBLEM #10
If not the clutch, it's usually broken relief valve spring(s). Accessible outside the transmission.
Sure hope your right about the relief spring. I have a copied repair manual and the trouble sooting guide for the power shift is missing. When the problem first started it would come and go. Now it won't pull in the fourth range but it will in the lower ones. The manual I have does have the power shift section just no trouble shooting. thanks for the info.
/ NEW YM336D PROBLEM #12
RB, Are you sure its actually staying in 4th gear ? Not trying to start anything....but... 4th gear can sometime feel like its shifted in and then just disappear when actually it has slipped (jumped) out of gear, especially if the other ranges (1,2,3) work well- the p\s is a very reliable unit, any change after clutch adjustment or inspection ? is your p\s lever on the column ?
you can also try holding in 4th gear w p\s in low and see if it moves
The power shift is on the transmission. It acts like not enough hydro pressure is getting to the clutch packs. In the lower ranges it feels strong. It will pull out on level ground in 4th but when it gets under a load such as a hill it's just like you shifted it into nuetral. It will stop pulling and roll backwards with the pto still turning the mower. I would like to take the unit off that holds the valve but I need to get the gasket. It may be a valve sticking or some dirt. Like I said earlier when it first started it would come and go. I think if was the clutch pack it wouldn't do that.
Yanmar Tractor Parts POWERSHIFT RELIEF VALVE SPRING
This is the spring for the FX models, but all power shift models have similar, some 1 spring inside another. You should not have to remove the valve to access it.
The symptoms match my tractor exactly. The valve goes in the back of the valve body with very little room to work maybe 2 inches between it and the shifter housing. I tried it again today and it is doing the same thing in all gears. Just not as bad in the lower gears.
Took the power shift valve body off today. It was a little dirty inside but no broken springs. Unless the valve was stuck I didn't see anything wrong. Broke a bolt off taking the shifter off but managed the bolt out after removing the valve body. Going to check with Hoye tomorrow to see if he has gaskets. I sure would have felt better if I had found something broken. If this don't help the only thing left is clutch packs. I don't know if I am up to that repair.
/ NEW YM336D PROBLEM #18
Isn't there another 2nd relief valve under the valve body? I know the 226 has one and it regulates pressure to the clutch packs. Did you slide out the valve spool for examination? I will attach a parts list for the 226 knowing it is not just like yours but I believe very similiar. If you look on the drawing on figure 42 and reference numbers 37 through 41 it shows the relief valve. Actual part numbers and descriptions are on figure 41 reference numbers 37 through 41. A mistake in the manual. C:\Users\mabe1945\Documents\i_89_1_YM226D.pdf
Yes I have the valve spool out. Yes there is a second valve and I will be looking at that today. I have the repair part of the manual on the power shift with breakdown of parts. Thanks for the input. Is the first picture the valve that controls pressure to the clutch packs? that is what I feel like my problem is.
/ NEW YM336D PROBLEM #20
is this the first power shift problem we have seen on here where it could possibly something inside the transmission?
I dont recall seeing anything more than low fluid, wrong fluid, or plugged screen or filter.
2011 Ford F-550 Bucket Truck - Power Stroke Diesel, Altec AT40G Boom, 45 ft Working Height (A61306)
2011 Ford F-550...
iDrive TDS-2010H...
Wolverine Skid Steer Stump Grinder (A64047)
Wolverine Skid...
2016 International Workstar 7500 T/A Dump Truck (A61573)
2016 International...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59912)
2018 VOLVO VNL...
2016 New Holland Boomer 47 (A60462)
2016 New Holland...
