Rear Remotes
/ Rear Remotes #1
Ole Orange
Ripley, Maine
L3650 DT GST & LA650A FEL
I have a 1992 Kubota 3650 with rear remotes I am trying to find the male ends that plug into the rear remotes but do not know what to ask for when I order my hoses. Is there a standard size or name for these?
Any help would be greatly appreciated.
Thanks:confused:
/ Rear Remotes #2
Wow!! I can tell you for sure - there is no such thing as standard. I've had special hydraulic hoses made for my current tractor and the "hydraulic hose company" had a great number of differing sizes, shapes etc. Fortunately my ends are OEM and the hoses were correct.
I guess I would first contact your local Kubota dealer and see if they can determine the type you need. Remember the rear remotes on your tractor might not be Kubota OEM. Any markings, numbers etc on the female ends might help in this ID.
/ Rear Remotes #3
You can either remove one of the QD and take it to a hyd supplier and match.
You can take all the numbers and manufacturer off the QD and order.
You can also switch out QD's for more common QD's.
/ Rear Remotes
Well I took JJ's advice and switched out the rear quick disconnects with new ones or thats my plan BUT...
How the heck do I remove the old ones from the mounting block they are in on my Kubota? It is a rounded orange steel rear mounted block that looks like its Kubota made. the QD's are inside two round holes and I can't get them out for the life of me.
another question if I have residual ATF fluid in my plow rams how much will it take to pose a problem with my Kubota super UDT fluid?
I still can't see how a single acting snow plow ram will self bleed out I am going to bleed my hoses and fill the rams all I can.
/ Rear Remotes #5
If a SA cyl is fully retracted, there is not much fluid in the cyl.
/ Rear Remotes #7
Don't forget your female couplers on the tractor are the brakeaway type. It would be best just go to a kubota dealer and get the male ends.
2018 John Deere 3033R (A64126)
2018 John Deere...
2004 New Holland TS115A (A64126)
2004 New Holland...
2009 International DuraStar 4400 Fuel Tanker (A62613)
2009 International...
2021 CATERPILLAR 279D3 LOADER (A64553)
2021 CATERPILLAR...
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A63118)
Bulk Lot of over...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
