I need some information on a Third Function Remote
/ I need some information on a Third Function Remote #1
lzicc
Pittsburgh, Pa
Kubota B2650
I have a new tractor on order and am trying to figure out what I would need from the Kubota website if I wanted to add a third function remote for the FEL and it is somewhat confusing to me. I am hoping someone can help me understand this. On the website I see the option for the Third Function Valve for Loader Implements. What else would I need to add to run let's say a Grapple? The tractor I have ordered is the L4060 with the FEL. I believe the handle for the FEL has a built in button for a third function remote. Do I still need to add the single hose quick coupler and the third function hose quick coupler?
/ I need some information on a Third Function Remote #2
You could add a diverter valve on the loader arms that will shift the curl flow to the grapple or switch it back for the curl function.
You could add a solenoid 3rd function to control the grapple using the switch on the lever handle.
You could run your grapple from the remotes on the back.
Do you want factory parts or would third party hyd work for you?.
Third Party would work. I am very unfamiliar with this part of the tractor. A divertor valve would be allot cheaper than a third function, correct?
/ I need some information on a Third Function Remote #4
I'm sort of lost here, why not just ask the dealer what needs to be ordered if you are looking at an OEM 3rd function?
If you are considering 3rd party, then you can either purchase a kit or source each and every part yourself.
If a person is to source each part and get the same parts that are in a complete kit, just get the kit, you will not save any money. Or you can build the system in some different way and save a few dollars.
/ I need some information on a Third Function Remote #5
I don't want to spend the extra money right now. I did ask the dealer about it and he said it would be under $1000 more. I'm already at the top of my buying budget, so I am going to wait. In the future, I may add this myself.
Thanks JJ. So if I buy the valve, I'll just need to buy the hoses/lines that go to the front of the FEL then, correct?
My curl function hoses would get disconnected from the FEL valve and go into this diverter valve along with the supply lines of the pump, then I would feed 2 hoses back to my curl function from the valve and also 2 lines to the front of the FEL. Does that sound correct? That is where I get a little lost on how this works.
You can get a diverter valve from baileynet.com for about $95.
Stackable Solenoid-Operated Circuit Selector Valve
It shows lever, but it is solenoid controlled used to switch the flow to two hyd circuits.
/ I need some information on a Third Function Remote #8
I have a third function on my L5740 and love it, but it's expensive, we ran hoses off the rear remote on our M8540 and will eventually put a diverter valve on another tractor, I have little knowledge on this so have depended on other members for guidance. Here are just a few threads.
http://www.tractorbynet.com/forums/...r-valve-vs-true-third.html?highlight=diverter
http://www.tractorbynet.com/forums/hydraulics/277559-diverter-valve.html?highlight=diverter
http://www.tractorbynet.com/forums/...pple-diverter-install.html?highlight=diverter
Thanks for the links TripleR. So of what I read, I would need to purchase the valve and the hoses. I believe my FEL lever has a switch installed already in it that I could use for the valve. I think that is what the switch would be used for if I purchased a third function. I don't have the tractor yet to know for sure. Now the one thing I do want to use this for is a rock hound landscape rake. So if I switch over the valve to power the RH, since the RH will need to keep spinning while using it, I would have to hold the curl lever in the open position or it would stop spinning if I let it go. I hope that made sense.
/ I need some information on a Third Function Remote #10
I had my Kubota dealer install the 3rd function system. They used a WR Long valve - the entire setup - valve, hoses, new joy stick and installation time cost $1195. I use the third function with the grapple I just bought. Looking at the finished setup - I'm glad I had it done by experienced maintenance folks. I understand the basic idea behind the 3rd function but the plumbing, routing, electrical requirements would have been well beyond my skills.
I know what you mean oosik, but the cost is the factor here. If I can get away with a selector valve and some hoses, it will be allot more cost effective for me. I do enjoy doing stuff like this, I just need a better understanding how it all works.
/ I need some information on a Third Function Remote #12
That is how I understand it, but as mentioned I really "know" little about any of this, J J and others can give you a definitive answer.
I appreciate the help TripleR. You led me in the right direction. Maybe JJ will chime back in. He seems to have allot of experience in this subject by reading the post you sent me.
/ I need some information on a Third Function Remote #14
If you use the curl up for the RH, you would have to bungee the lever on for continuous operation.
The diverter valve needs some short hoses and a switch to control the diverter.
The diverter valve will switch from curl to RH, but the FEL lever Curl up will provide the flow.
One of the other guys used a 3rd function solenoid valve to provide continuous flow to the RH using an on/off switch.
You could also use the 3rd function to control a grapple using a momentary switch.
Thanks JJ. So the diverter valve would mount close to the existing FEL valve. I would then need to run long hoses does to the front of the FEL for the RH or anything other attachment. Is that correct?
/ I need some information on a Third Function Remote #16
Just for the record, the manual for my WR Long 3rd function valve kit for a Kubota 4330 cautions against using their valve for continuous flow. I guessed that the solenoid would burn up if it is energized too long. It's been great for momentary use, like a grapple. This particular valve was purchased 5 or 10 years ago.
/ I need some information on a Third Function Remote #18
You have to get the right valve for hyd motor.
J_J
I have a question about hyd control valves for orbit motors? Over the yrs I seen orbit motors operated on regular ag tractor remotes with no ill affects other than heating of the hyd oil. The implements I'm referring to are Vermeer hay rakes,JD hay rakes,augers & planters with orbit motors. So how do these orbit motors operate on regular scv's with no problems?
Thanks,Jim
/ I need some information on a Third Function Remote #19
Those scv might have motor spools in them.
There is usually no problem with running a hyd motor from any hyd valve as long as the valve ports are matched to the pump flow.
If spring centered valve , you would have to bungee the lever on.
I would use detent motor spool valve for hyd motors or proportional valves and dial in the speed.
A motor spool valve is designed to allow the spinning hyd motor with load to decelerate with no shock involved.
They might even use special solenoid valves for constant on to take care of the heat problem..
/ I need some information on a Third Function Remote #20
Using a slow turning hyd motor or a hyd motor with very little centrifugal force, one could use any valve matched to the flow.
Something like a hyd driven bush hog, would require a motor spool valve, whereas a cyl spool valve in neutral would cause the hyd motor to act as a pump and will try to pressurized the circuit.
With nowhere for the fluid to go, damage could occur.
The motor spool allows the flow to subside with very little pressure until the motor stops.
You could do the same with a cyl spool if you lowered the flow gradually. .
If valve has float, you could use the float mode to let the hyd motor decelerate.
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
200 GALLON FUEL TANK W/ 120V PUMP (A64277)
200 GALLON FUEL...
2013 CHEVROLET 2500 HD (INOPERABLE) (A65643)
2013 CHEVROLET...
2004 Chevrolet Tahoe 4x4 (MPV), VIN # 1GNEK13Z24R318274 (A61165)
2004 Chevrolet...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A64194)
2019 Allmand...
2015 Chevrolet 15 Passenger Express Van (A62613)
2015 Chevrolet 15...
