Filling just the rear?
/ Filling just the rear? #1
mx377
Mich
LS XR4046H
As I stated in my last post, I have a new LS 4046 on the way...
My question now is... If I'm going to be doing allot of FEL work in the woods with grapple Should I only fill the rear or go ahead & fill both front & Rear?
/ Filling just the rear? #2
I don't see a reason to load the fronts for doing loader work but that's just me. Maybe for snow plowing you would load all 4 for extra weight.
And congrats on the new tractor. Don't forget the pics when it arrives.
/ Filling just the rear? #3
I doubt it will hurt anything but given the size of the front tire its not going to do very much either. If you want more weight on the front for a particular project load the bucket full of dirt and dump it out when you're done.
I'm mainly going to be using it to carry logs out of the woods & loading on a truck. will loading the rears be enough ballist?
/ Filling just the rear? #5
If im at the max of my loader, I can carry the logs but I'm also ready to drop the bucket in a heartbeat too and keep it very low to the ground. You're still better off with some ballast behind the axle, but yes the loaded tires will help significantly. Try it out and go from there.
/ Filling just the rear? #6
I use my tractor mostly in the woods, with very hilly ground. I have loaded tires, front and rear. I wanted a lot of weight low to the ground. I also use rear ballast whenever I am using the FEL. It makes it easier to steer. It probably makes it easier on the front end, as well. It is surprising to me what a large difference rear ballast, held low, makes in providing a feeling of stability when I have something heavy in the FEL.
/ Filling just the rear? #7
When lifting with the FEL, the front tires become a pivot point. Any added weight in the front tires will not help with keeping the rear tires on the ground. You need to counter the weight that is ahead of the front axle, by adding weight to the rear of the tractor, like filling the rear tires as you mention, or adding a ballast box, weights, or a heavy implement to the rear of the tractor.
When I had my IH2500b (same thing as an IH 574) I had 54" tall x 14" wide tires filled with sodium chloride(about 550# in each tire), and a 55 gallon drum of concrete on the 3pt hitch, and a full cab, and a full tank of gas, and I could still lift the rear off the ground with a big enough bunch of logs. So, tractor weighed about 4000#, plus weight of FEL and bucket, another 1000#, plus 1100# of salt water in tires, plus cab, 500#, plus 55 gallons of concrete, guestimation at 5-600#. That's over 3000# of added weight. Your mileage may vary. :)
/ Filling just the rear? #8
Filled rear tires, wheel weights, and rear counterweight with chains as needed works for me.
Thank you everyone for your first hand info! I'm off to look for info on building a counter with this 55 gal. drum I have laying out back....
/ Filling just the rear? #10
Filling the fronts only gets you more weight for better traction, thus better steering. Better traction equals higher capacity for pulling implements. Most people do not fill the fronts, I am not most people and I have the fronts filled on both my 32hp & 75hp tractors. Has not hurt anything as of yet that I am aware of. ;)
/ Filling just the rear? #11
If you do much high speed road travel the water in the front tires shakes and wears front end steering components a lot quicker.
/ Filling just the rear? #12
I suppose this might be true, :confused3: but I have noticed no difference at 20MPH with my 75hp tractor or at 11MPH with my 32hp tractor, not that I road my tractors at full speed all that much.
As far as things wearing faster, no doubt, but in reality for most of us it is such a small amount, will it ever really make a difference for us? I have noticed zero wear and am at 10 & 8 years with these machines. I have no doubt that a commercial user sees the additional wear and has to decide if the benefits of the additional weight out weigh the additional wear on the machine. In my opinion, the additional capabilities out way the additional wear on the machine.
Each person has to make that decision for themselves. ;)
/ Filling just the rear? #13
I can see what you are saying and it really is dependent on road travel, tire size and amount of use. I just hit 12,000 hours on my 200hp 4x4 and am just now rebuilding the steering cylinder. On a small tractor just having a loader is already alot of extra weight added to the front tires.
/ Filling just the rear? #14
I filled my fronts on my L4330 and have noted no negative consequences as yet. It made my tractor much more stable when going up my steep hill in front of my home.
And I've noticed the opposite although I can't vouch for the actual speed. When running down my one mile gravel road, just driving, not hauling or grading or whatever, I've noticed less "porposing" with my front tires loaded than when they were not loaded. This was my biggest worry and it turned out to be nothing.
YMMV, but front tires loaded has worked for me.
/ Filling just the rear? #15
So in what way is it that filling the front tires gives you more stability?:confused: The front axle pivots side-side. I suppose that it holds the front down better with the weight in general, but with it being able to oscillate side-side, not sure how much stability is actually added other than from flipping over backwards.:eek:
Remember, I have all 4 tires loaded on both of my utility tractors, so you don't have to convince me of the benefits and as far as I'm concerned, there are no negatives, but that is for me with my circumstances. ;)
/ Filling just the rear? #16
We always loaded the front tires of all our farm tractors for extra weigh for lifting larger 3 PH implements. All weight helps even if it is just a few hundred pounds. I have loaded the rears on my LS but not the fronts but I don't see that it would hurt. I may load them due to some noticed wear where they must be spinning a lot so a little more weight may help reduce the wear. I think the fronts must pull 60% or more of the load because in 2 WD it doesn't take much to cause wheel slippage.
/ Filling just the rear? #17
I have always just filled the rears.Most advise the same but a few here have loaded the fronts.You may also want to consider so additional rear weight to help counter balance.I always have on a box blade or rear blade.
I have lifted my rear(on the tractor) even with loaded tires and a 700lb.box blade on the back.
/ Filling just the rear? #18
Less bounce going up steep hills, which means it doesn't feel like it's going to flip over backwards.
2014 FREIGHTLINER CASCADIA 113 S/A DAY CAB TRUCK TRACTOR (A59912)
2014 FREIGHTLINER...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2020 Peterbilt 579 T/A Sleeper Cab Truck Tractor (A61573)
2020 Peterbilt 579...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
