can I do it with my tractor?
/ can I do it with my tractor? #1
youngoilguy
NE Ohio
Kubota
Hi all,
I have a Kubota B7510, its about 23 hp and 16 at the pto (or there about). I'm building a house on a 4 acre lot. not a tree in sight. it used to be a hay field (for about 50 years). There is a good amount of topsoil. Since its all timothy now and bumpy (from old farming ruts) I need to make it smooth to transform it into a yard. I have a 50" Befco tiller and a back blade. Do you think it is possible to till about 3" deep and then use the back blade to smooth it out? Am I taking on too much? The excavator wants $2,000 to finish grade the lot, thats without grass of course.
Input?
Suggestions?
I need both.
-Mike
/ can I do it with my tractor? #2
With the right soil moisture you should do very well with the B7510 + Befco Tiller (highly regarded implements) + back blade.
You will probably have to till, redistribute with back blade, till, redistribute, till etc.
To wet or too dry and all you will have is frustration.
Get a soil test and amend specifically for grass you will grow. A cheap test plus soil amendment will pay big dividends for the next 10-12 years.
Grade so rain and roof runoff moves away from the house on all sides.
Let settle through several rains, hopefully gentle. Ultimate grade before seeding. Roll in seed.
HAVE FUN.
/ can I do it with my tractor? #3
I tried grading the floor for my arena, which was about 1/4 acre, and ended up hiring someone. Maybe your skill level is higher than mine, but it takes a fair bit of skill to get things flat over large distances. You could try doing a small area and decide if you get the result you're looking for, that would also let you estimate how much time this is going to take. You might check around for prices on excavating. I think a landscaper might have equipment more suited to the task than an excavator. For reference, I paid $60/hour for the machine and $20/hour for the operator. The machine was about 100hp Takeuchi skid steer, which would be way overkill for what you're trying to do.
/ can I do it with my tractor? #4
You can smooth the ruts out with the tiller and after tilling, dragging something that will carry a bit of dirt--like chain link fence with maybe (two) 2" pipes tied on top of the fence. Personally, I think that would work better than the back blade for smoothing.
I don't think you will accomplish much in the way of changing the grade (overall slope) over a large area with your tractor. For one thing, it means moving a lot of dirt from one area to another. If you want to try you could choose a small test area. Fasten a level on your tractor that reads level when on level ground, set a target bubble range like 1/4 of the bubble outside the level marks and see if you can work to that slope keeping the bubble in the same position. I think it would be easier with a FEL bucket than a 3pt back blade with no down pressure to use.
/ can I do it with my tractor? #5
it can be done BUT with a LOT of work and TIME. If you have the house done then work on just the house area & do it in sections you may be happy or hire it done by a landscaper who has proper equipment. The Back Blade would not be best for leveling, use either a Box Blade or Land plane. Any section you till will end up slightly lower once it settles than the dirt right next to it left un-tilled. I know this from experience when I tilled rows for trees which the rows ended up 2" lower in middle than each side.
Also you MAY want to spray and kill existing grass and burn it of FIRST, as tilling grass always leaves a LOT of root clumps that get spit out of the tiller no matter how slow you go. Getting everything tilled the same depth also it hard unless you can set draft control on your machine which I don't think it has>?
Mark
/ can I do it with my tractor? #6
I like the idea of the tiller , probably going over it a few times . I would then hire a good dozer operator as he will do the job of leveling in no time compared to TRYING with a back blade .
/ can I do it with my tractor? #7
+1 on the landscaper. Had someone with a harley rake come in and nice up a pit i had filled with all kinds of dirt, he had it done in an hour, would have taken me at least 4.
/ can I do it with my tractor? #8
Smoothing out a bumpy hay field can definitely be done with what you have, although after you have tilled it and backbladed the chunks flat the final conditioning would be easier to do with a ring conditioner than a backblade. If you know anyone with a ring you may be able to borrow one, because basically everyone with a riding ring has some version of one. You simply can't maintain your ring without one.
I would suggest you do it in batches though, of 1/4 to 1/2 acre. It will make the job more manageable, decrease erosion, make it easier to seed, etc. You also may find that one you have two acres done, that you have enough mowing and may not want to have to mow the whole 4. Nothing wrong with having a couple of acres of wildflowers to keep the bees happy, and then just bushhog it once a year to keep out the alders, instead of having to mow it every week.
If you are in a hurry to get a place for the kids to play than hire a pro, but if you are not in a hurry then have some fun with your tractor and get 'er done at your own pace.
/ can I do it with my tractor? #9
Wouldn't a landscape rake with gauge wheels be a better choice than rear blade. I have a 6 footer on my 2400H and it works much better for smoothing and removing clumps, clods, etc. than the box blade.
/ can I do it with my tractor? #10
Filling in ruts and finish grading are too different things. Ruts are easy and finish grading takes a lot of skill, experience and the right equipment. I believe you can fill in the ruts okay but need to add a good landscape rake to your equipment list (with wheels). I would not attempt finish grading for a home site.
I just put in a driveway that went up a hill, then flattened out and curved around to the area the house will be. I have many hours in it, along with more and larger equipment than you have mentioned. I got pretty good with the ROBB and landscape rake (with wheels) using the TNT hydraulics and the driveway is graded exactly like I wanted. I have received comments the job looks professional.
I am leaving my home site grading to professionals after I cut down the trees and have a mini-x dig up the large stumps I can't remove.
I can't emphasize enough how important wheels are (to us folks who do not have professional level box blade and landscape rake skills) on a heavy landscape rake to spread the loosened soil- evenly.
I would not attempt to finish grade 4 acres or 1 acre for a house. I think your equipment is too small and there is not enough of it.
/ can I do it with my tractor? #11
Why not just try it with your tiller and blade. Turn the blade backward to drag just a bit of dirt and it will work better for levelling ruts.
Till it first and let the back plate on the tiller drag as much as possible. It will auto-level a lot of it as you till. Then get the blade on and back drag it in an x pattern then go crosswise of your X and it should be pretty level. Dragging an old piece of chain link fence would help also.
If you cant get it to your satisfaction, then you can hire it done with nothing but a little fuel and time invested.
/ can I do it with my tractor? #12
Agree with Gary. The tiller will level quite a bit, especially with repeated passes. You never said if you already have good drainage/slope, if not it would be difficult because the excess dirt has to go somewhere if you attempt sloping it. You have the equipment, might as well try it!
A landplane would be nice, you could use mine but it's too big for your machine.
Where at in NE Ohio? I'm just south of Canton.
/ can I do it with my tractor? #13
Yes, your machine will do the job. It will take forever, won't drain right, so many things to consider.....
2 grand for a pro to smooth and grade it for drainage sounds like a lifetime investment that will be money very well spent.
Then you can go in and play, making level areas for kids playsets, picnic areas, firepit, later a pool.
/ can I do it with my tractor? #14
I would add a drag to the equation. Just a couple logs or RR timbers chained together will work. Wrap some fencing around them and you can get a little cutting action. Harrows are also handy, but you have a tiller.
