The First Beast is Complete..Serious BoxBlade!!
   / The First Beast is Complete..Serious BoxBlade!!
Video, video, video
Not forgotten! Ted has had a rough year outside of work so far. First, back surgery and then his dad, Charles, passed away on August 25th.
Hopefully, video time will be coming soon!
Travis
   / The First Beast is Complete..Serious BoxBlade!! #92
Travis
Sorry to learn of the loss of his dad and the surgery. Life has a way of messing up man's plans sometimes. Your company does seek to build some nice equipment. Best of luck.
Thank you. Ted seems to be doing great since his surgery, and hopefully he'll be making some new videos soon.
We are still going strong, with sales increases every month so the future looks very bright for ETA!!
Travis
   / The First Beast is Complete..Serious BoxBlade!! #94
Hey guys, I'm bumping the thread for a video of that beast in action! :D
   / The First Beast is Complete..Serious BoxBlade!! #96
Seems like it is a bit heavy.
I am all for solid construction and robust attachments. But this is massive. Perhaps too heavy....
Also, for something like this, if it is really a top shelf BB, would recommend hydraulic scarifiers.
For comparison....
When we do work with our boxblade, we are pulling a Frontier (Deere) BB4296H, 96" box blade with hydraulic scarifiers.
This is being pulled behind a John Deere 5095M, Cat 2 hitch, with fully loaded tires and always an attachment on the front.
The BB4296 weighs 1,310 pounds. For reference, our work is up in the mountains in Vermont. We use it for both road/driveway work, as well as grading fields; both overgrown meadows that we are restoring, as well as food plots we are carving out of the woods. Box blade takes more than its fair share of abuse when it hits big stones, that for whatever reason we did not kick up with the plow and remove before blading/grading/smoothing.
So 95hp tractor, fully loaded tires, another 1,000 to 1,500 lbs on the front typically. Plenty of weight, plenty of hp. But I am not sure that I would want to pull a box blade that is pushing 2,300 pounds. There are times when the tractor will struggle a bit, and even bog down, when conditions are wet and the box is full of wet dirt. I would guess that for this ETA box blade, when fully loaded, the combined weight of the box blade and the material will be pushing up against the specs for the 3pt hitch for many tractors at 100hp and below.
Bottom line, is that it strikes me as a bit heavy. This coming from someone who likes things overbuilt. Almost too heavy for Utility sized tractors. Also, for a top of the line BB, should have hydraulic scarifiers, at least as an option.
On a good note, great to see folks making things in the USA.
   / The First Beast is Complete..Serious BoxBlade!! #97
For comparison....
Going off Ted's comments when they released it, the intent was to be very heavy, and a true beast.
   / The First Beast is Complete..Serious BoxBlade!! #98
And I think the large one was supposed to be 100HP minimum.
Yes, the Beast is the biggest and baddest 3pt box blade on the market that I know of. It is built for serious land clearing applications and is made for category 2 and 3 tractors up to 220 HP.
We do have lighter offerings. The next step down is our Lockable Floating Tailgate models designed for up to 125hp. They can be ordered with standard shanks or with our custom 1"x4" T1 shanks that are built in house. We even offer them with the same 8" wide Vaulk heat treated Viper cutting edges that we use on the Beast models.
Hydraulic shank models will be offered eventually, but not on the BEAST.
Travis
   / The First Beast is Complete..Serious BoxBlade!! #100
Well, we have made one step. A New Holland TL90 dialed up to 107 PTO HP for testing the Beast and other heavy attachments.
Using judgement based on your screen name, I think you'll appreciate the dyno video!
I'll remind Ted that you're waiting!
Travis
I saw the thread about the New Holland purchase so I was hoping re bumping the thread would remind Ted we like watching him and peanut demonstrate attachments!
1026mrg- The whole point was to be the biggest baddest out there. I don't think your 5095 would like that BB much, but it sure wouldn't have any problem getting it to dig in and get some work done! Most of today's modern BB's are built to the lightest spec possible and that makes them terribly ineffective at moving material. Ted has received TONS of feedback from TBN for producing a heavier lineup of blade that true tractor owners and not bargain hunters would be interested in and satisfied with!
2017-2022 Ford F-250/350 Rear Bumper (A49461)
2017-2022 Ford...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
2010 Triple B Gooseneck Inclosed Car Trailer (A50514)
2010 Triple B...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
C13 MOTOR (A50854)
C13 MOTOR (A50854)
