Battery For 425 (Kohler)
/ Battery For 425 (Kohler) #21
I do apologize for hijacking this thread.
/ Battery For 425 (Kohler) #22
I replaced both ground and hot wires to the battery in case that was not clear. Each is only one piece. I did not tie the ground directly to the starter.
I used it a bunch today and cannot say if started better. I have found that it starts easier when cold if the throttle is set to idle. That seems strange to me.
I always start mine with the trottle off, full choke and work up to 1/2 as I crank. I used to start it at 1/3 - 1/2 throttle, but I started having issues. It may be time for a valve ajustment on my Kohler. I have never done it in 13 years, and around 500 hours.
/ Battery For 425 (Kohler) #23
I have adjusted mine twice at about 1000 hours. I cranked the engine a few minutes ago to see if the lights went off. It started right away at idle and no choke. It had been off for 5 or more hours.
Bobcat MT85 (A60462)
2017 Ford Escape AWD SUV (A61569)
2017 Ford Escape...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
John Deere 1023E (A62177)
John Deere 1023E...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 4520 (A60462)
John Deere 4520...
