Oil & Fuel Storing Tractor Over Winter
/ Storing Tractor Over Winter #1
Freeborn
Member
West Central Minnesota
John Deere 3520, John Deere X740
Hi Group,
New owner of a slightly used tractor here and Im looking for advice on what steps I should take for preparing my tractor for Winter Storage. This is my first tractor so I have some learning to do.
The Tractor is a 2008 JD 3520 with 400 hours. I live in Minnesota although the tractor was purchased in southern Indiana and shipped to me. The tractor will be stored on my hobby farm where I do have access to it but I dont have a need or plan to run the tractor in the winter unless it is a good practice.
Unfortunately here in Minnesota we are headed into fall and winter will be close behind so I need to prepare the tractor for storage over winter.
What steps should I take to get my tractor ready for storage? I have checked the antifreeze and thats good but what other steps should I take to store my tractor? The fuel tank is a quarter full so Im planning on filling the tank but would you recommend an additive? Do I need to do anything with Hydraulics?
My thoughts are that I would change the oil and transmission fluids next spring but I am open to recommendations.
Thanks for the help.
FB
/ Storing Tractor Over Winter #2
Owners manual should say (you should have one).othewise, I'd run it hard at a task you got it for, then change out hyd fluid/filter, engine oil/filter, coolant with additive. Nothing bad will happen to the new fluids over winter and you'll be sure there's no water or contaminants in there.
Will it be indoors? I'd take the battery to my basement and charge it occasionally. I'd air the tires and jack the tractor onto blocks to take the weight off them. Is vandalism a concern?
Do a search on here for "chewed wires" and treat against rodent snoozers. Put a rag lightly into the exhaust tip (I assume it's down-facing.) If outdoors, cover with a soft tarp that won't move around and scratch the paint. Tip the bucket so water won't sit in it. Send us a picture of your new rig.
Shouldn't take more then a few hours and give peace of mind.
Jim
Thanks
Yep, I have a manual and obviously I need to get to the winter storage section. The tractor will be stored in a metal Pole Shed with a concrete floor. Knock on wood, no problems with vandalism yet. I have been storing boats, ATVs and other items for some time so I do have practice on killing off the rodents. I’ll search for the thread you listed and take precautions.
Blocking up the tractor is not a problem. I have and still do change oil on my vehicles, lawn tractor and light equipment so I’m thinking I shouldn’t have a problem with the tractor. It will be a little bit of a learning curve but it can’t be that difficult. Are there any special tools I need for getting filters or the oil drained? Anything that makes it easier?
Thanks!
FB
/ Storing Tractor Over Winter #4
Can't go wrong with what's been suggested so far. My tractor doesn't get stored here in winter. It gets used for snow plowing. Mine is babied being kept in a heated garage (45 degrees).
/ Storing Tractor Over Winter #5
sounds like you have a plan & good advice. although it will be stored in an enclosure, you might keep in mind varmint damage leaving it unattended esp to wiring, hoses, etc even from mice. i would leave the hood open (they don't like light) and place mothballs in vulnerable areas of engine, seat, etc. amazing how just much damage they can do in a short space of time.... regards
/ Storing Tractor Over Winter #6
Good advice. Like already stated, block up the tractor so the weight is off the tires, and remove the battery! Full fuel tank, with diesel additive, and clean fluids and you will be good to go in the spring- July? Rodents love to nest in tractor engine areas, so deal with 'em!
/ Storing Tractor Over Winter #7
Drier sheets work very good for Varmits.
/ Storing Tractor Over Winter #8
are they flammable? if so, would not recommend for engine compartment even if just for temp storage...easy to forget over time. mothballs dissolve over time...
I have been Using Dryer Sheets in my boats for a long time and they have worked well. I roll up 1/2 dozen of them together, put a tie around them and then lay several of these in my boat. I could do the same with the tractor and just tape a piece of paper on the tractor identifying where I have them.
Here is a couple pictures of the new tractor.
/ Storing Tractor Over Winter #10
I use them under the dash board.
/ Storing Tractor Over Winter #11
great idea murph, will utilize them along w/my current methods...sure can help avoid wiring harness nightmares, easy to forget the precautions.
/ Storing Tractor Over Winter #12
Hadn't used my mini-excavator gorgeous 2 weeks because harvest season in full swing. When I needed to use it no fire. The only light that came on when I turned the key was glow plugs. Opened armrest where switch is located - 2 wires chewed through and 4 damaged. Checked fuse and relay position under the seat - needed a total of 13 splices to repair. Cat places the Operator's Manual under the seat secured with a lanyard. They had shredded the entire manual to use gorgeous a nest. I have always wondered why they like wiring do much - the taste of copper? The problem is squirrels. While helping me splice my wife spotted a squirrel run under the mini into nearby trees. I got my 12 gauge single shot and kept it by the mini while we continued to work. A little later shed potted a squirrel, probably the same one, in a tree. Got him. 12 gauge is now sitting by the door with a box of shells in my desk. Got another one yesterday. When we finished fixing the mini we packed it with mothballs. Certainly a different odor working with it today. Good to hear about the drier sheets. Our larger tractors that get stored for winter will get them.
/ Storing Tractor Over Winter #13
12 gauge for squirrels? Anything left?
To the OP - JUST IN CASE you have to fire'er up during the winter keep some "emergency supplies".
Try to ensure you empty the fuel tank JUST before storage and then FILL it with winterized diesel. There's nothing like trying to start a diesel at 40 below when your fuel was meant for 50 above (10 Celsius). I KNOW. In Vermont I tried to keep a 5 gallon Kerosene can handy.
Get a jug of diesel 911
Might get a magnetic block heater. I've used one in an "emergency" with blankets on the oil pan. But I've also used an electric frying pan. It takes hours but it meant the difference between start or stay.
And record ALL serial numbers w/ pictures just in case of theft.
Supposed to be a COLD winter. I imagine it will even freeze (that's when water turns to ice) in Mississippi.
If you do change fluids use a light synthetic.
/edit - and put your tractor in where it says tractor under your Avatar!
/ Storing Tractor Over Winter #14
All good ideas. If you're feeling particularly proud, a coat of wax on painted surfaces won't hurt any. Nice looking machine.
Jim
/ Storing Tractor Over Winter #15
Jim
Hi Group,
A couple of additional questions:
Im picking up filters and oil tomorrow and plan on starting with the engine oil first. Since I purchased the unit used I am planning on sending the oil out for testing at Blackstone labs. Hopefully the results are decent.
The oil thats in the tractor appears old and based on the owners manual (if you can trust the log in the manual) the oil has not been changed for about 120 hours. My question is do you recommend flushing the oil and if I change over to a pure synthetic what would you recommend. Id like to get everything out of the system so I was thinking I could change the oil twice, once with an inexpensive conventional oil and then again with a synthetic. Is this a good idea or are their other things you would recommend.
Thanks again,
Appreciate the help!
FB
/ Storing Tractor Over Winter #18
Great looking Deere. Just out of curiosity where in southern IN? Just curious if I'm familiar with the dealer.
Write Stemle was the Dealer. They have several locations and seemed good to work with.
/ Storing Tractor Over Winter #20
Glad to hear it. I'm not far from one of their dealers (the one in Ireland, IN) and have stopped in several times to browse.
2025 60in Bucket Skid Steer Attachment (A61572)
2025 60in Bucket...
2022 John Deere 325G Track Loader (A63111)
2022 John Deere...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2016 Chevrolet...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
Caterpillar 931/953/953C/963/963C Parts and Service Manuals (A63117)
Caterpillar...
