293 Tranny creep
/ 293 Tranny creep #1
tkappeler
Hainesport, NJ
TYM T293
I have a 2012 T293 that has worked flawlessly ... until recently. Most of the time, when you let up off the pedel, it will creep in reverse. This happens about 70% of the time. I imagine that there is an adjustment for that. Does anyone have the repair manual for that? Anyone experience this before? Any suggestions on how to fix it?
thanks.
/ 293 Tranny creep #2
The reverse pedal on my 503 wouldn't completely return to neutral, all I did was just get underneath and lubricate all the pivot points with WD40, worked fine afterwards.
My Kubota would constantly do that unless it was cleaned and lubricated
/ 293 Tranny creep #3
If the lubricating doesn't fix it look in your operators manual and it will show the pedal adjustment. Under the platform by the pivot point for the pedals there is a bolt to loosen and slightly turn the adjusting nut. Then retighten the bolt and get on the tractor and give it a try. Depending on which way you move the adjusting nut will make a difference on the pedal centering. You will need to be on the tractors seat when you test it as if its to far one way or the other the tractor will move in that direction when started.
/ 293 Tranny creep
Thanks. I will try that first.
I poured over the operator's manual and did not see any adjustment. If the cleaning/lubricating does not work, I will look for the adjustment.
/ 293 Tranny creep #5
thanks.
Good Afternoon!
Could you private message me an appropriate email address?
I have a diagram detailing several ways to fix this issue!
/ 293 Tranny creep #8
new member.. hello from arkansas...
I have this exact problem.. only creeps forward.. if i slightly lift on the pedal it stops.
only 30 hrs on my new T293HST....
could you send me the instructions also.... dealer is a major trip....thanks!
/ 293 Tranny creep #9
/ 293 Tranny creep #10
Hopefully this helps you.
/ 293 Tranny creep #11
myyaz33 has the fix for you - just be aware that 1) it isn't running when you do the adjustment and 2) it doesn't take much of a turn to make a big difference, more of a 'suggestion' of a turn should do it. It is easy to do though.
/ 293 Tranny creep #13
Thanks for the tips.... the "isn't running" part is funny:laughing:
2023 KUBOTA KX040-4 EXCAVATOR (A65053)
2023 KUBOTA...
BOBCAT SKID STEER BUCKET (A64553)
BOBCAT SKID STEER...
2018 Ford Focus (A61574)
2018 Ford Focus...
PALLET OF AXLE TAKE OFF'S & CYL (A64278)
PALLET OF AXLE...
1999 INTERNATIONAL 4700 - 6 WHEEL GRAIN TRUCK (A64278)
1999 INTERNATIONAL...
2023 JOHN DEERE 333G SKID STEER (A65053)
2023 JOHN DEERE...
