If you have Toolcat questions, ask them here...
   / If you have Toolcat questions, ask them here... #231
i cant get the rear wheels to move at all. its tracking a little off, and i cant get the rear light for tires being straight to come on.
doesnt matter if the switch is in 2 or 4 wheel steer position.
the rear tires never move?
help?
   / If you have Toolcat questions, ask them here... #232
help?
What series is it?
My series F rear steering hydraulic cylinder is operated by an electric solenoid.
   / If you have Toolcat questions, ask them here... #233
thats the problem, i have read in other posts where to find the serial number, but the only thing i can see is a mutilated sticker in behind the loader arms.
isnt there a serial number stamped into the frame somewhere?
   / If you have Toolcat questions, ask them here... #234
Serial number plate is attached to the right rear of the toolcat (at least on the early models). Look where a bumper would be if it were a truck. If you can't find it then post pics of the loader arm. The design changed and you can tell if it is an A or B model versus C and beyond.
   / If you have Toolcat questions, ask them here... #235
   / If you have Toolcat questions, ask them here... #236
   / If you have Toolcat questions, ask them here... #237
That is the newer style arm so it's not and A or B model. Did you locate the Serial number plate on the rear of the machine?
   / If you have Toolcat questions, ask them here... #238
No I did not see a plate with the serial number, but I did get the rear steering to work, I traced the wires to the solenoid a, and a mouse had a nest in there and chewed the wire!
So on to my next problem, my oil pan leaks at the bottom corner and bobcat wants 340.00 for the oil pan plus 30 for the gasket.
Does anyone know if I can get the oil pan from kubota? It is a kubota engine isn't it?
Or if someone has a part number for it, the dealer needs the serial number from it to order the pan
   / If you have Toolcat questions, ask them here... #239
and is it easy to remove the oil pan?
any tricks or tips?
   / If you have Toolcat questions, ask them here... #240
what is the engine code
1000 Gallon Supply Tank (A53314)
1000 Gallon Supply...
Pallet Of Mini Excavator Attachments (A47477)
Pallet Of Mini...
2014 Nissan Rogue Select SUV (A55853)
2014 Nissan Rogue...
New/Unused Pallet Forks (A54865)
New/Unused Pallet...
