Ordered a 5045E
/ Ordered a 5045E #41
I have 300 odd hours on it now. Ive talked about it a lot in other threads especially snow removal ones. Except for a problem with the 3PH which I caused by over loading it it has been good.
Guess I am going to have to do a search to see what else you have written on it. I am very interested since I just ordered a new one. Should be here in a couple of weeks. Am I going to wish I got a Kubota instead? Sure hope not. Anyway, that plow you rigged up appears to be the cats meow! I have a nice rear blade but that really looks like it would push some snow. Do you ever wish you would have got one with the exhaust below instead of above. I am in what appears to be a similar location with lots of woods and trees. How did you overload your 3ph?
/ Ordered a 5045E
Hooked onto a big log that was frozen in at twenty below by the 3PH crossbar in the raised position. when I came to the end of the chain the log didn't move but something went inside the tractor. After that the arms would settle down as soon as I shut the engine down and I could not pick up any implement with it.
The plow is just a Fisher eight footer with wings hooked to an adapter plate I had built. The third function on the loader runs the swing cylinders. Works pretty good as long as you stay off of big rocks.
/ Ordered a 5045E #43
Thanks for the update! Sure hope you get that thing working the way it should!
/ Ordered a 5045E #44
vtsnowedin , Another question on the hood or grill guard! Can you tell me what the width of the front of your tractor is where it would bolt on? I have one spotted and I think it is the right one but I can't find anywhere on the net that has the dimensions listed. Thanks allot!
/ Ordered a 5045E
Mine is 26 inches wide.
/ Ordered a 5045E #46
Is that the width at the widest point or where the bracket attaches? I am most interested in finding out the inside measurement of where it attaches. I am thinking and hoping it is around 21 and 1/2 inches or so. Thanks so much for the help!
/ Ordered a 5045E #48
That is the grate itself so it is the inside measurement between the brackets. I have My grate taken off as it fuzzys the headlights for night work in snow. You might check here.
Hood guard for 5045D, 5055D, 5045E, 5055E, 5065E, and 5075E 2WD and MFWD Tractors
Ya, I have been there numberous times. doesn't give me any measurements. It is the main hood guard that I am interested in learning the width of the bracket where it attaches to the tractor, not the grate or grill guard part. The part that is bolted onto the frame of the tractor is what I am after. Hope that makes sense. I appreciate your help! I think the part number is BW15817
/ Ordered a 5045E
Well yesterday when you asked it was raining like a cow on a flat rock and the tractor is parked outside two hundred yards away. I just went down in the basement and measured the grill where I had it hung up. Today I'm using the tractor as a big green wheel barrow so I just put a tape on it for you. The brackets are 21 and 1/4 inches apart and each side has three two inch pipe spacers between the frame and the brackets. Apparently the hood guard fits some bigger tractors just by using shorter or no spacers.
/ Ordered a 5045E #50
Oh my, the plot thickens! Thanks allot for your efforts in doing this for me. The two inch pipe spacers has me puzzled. Would that mean the actual width of the tractor itself where the unit attaches is only about 21.25 less 4 inches or 17.25?
OK, I think I get it now by looking at this picture of one. If I look close, I see the spacers you are referring to. Never even thought about using spacers so I think the one I am looking at might work after all.
Thanks so much for your help!!
http://salesmanual.deere.com/sales/salesmanual/images/NA/materialhandling/features_attachment/553_loader/498527_bw15817_hood-guard_553.jpg
/ Ordered a 5045E #51
OK, well, I got the main frame of the guard on order and I thought I got a good price on it, about 100.00 shipped but now I find out that it doesn't come with the bolts or spacers! Those spacers through John Deere are terribly high priced! From what I have seen, about 17.00 each and I think it takes 6 of them! I am going to have to try to find a different source for those, I guess. When you refer to the 2 inch pipe spacers, is that the exact measurement for them? Do you know what the diameter of them is? I don't want to have more in the spacers than I have in the guard. I will end up at the cost of a new one at that rate. Thought I was saving money and now I am not so sure!
/ Ordered a 5045E
Most everything on a 5045e is metric. So those spacers are probably 50mm long. bolts and spacers from your dealer shouldn't be to bad.
/ Ordered a 5045E #53
Thanks, I will check with him but everything I have seen on the net is about 17.00 or more for each spacer. I may end up having to make some out of pipe or something!
/ Ordered a 5045E #54
I just thought of an idea that should save some money on the spacers. Don't know why it took me so long. Anything wrong with using several washers stacked??
/ Ordered a 5045E
Well two inches is quite a stack and the hardware store probably gets thirty cents a piece for them but I guess it would work.
/ Ordered a 5045E
Ya, I have no doubt I could beat the spacer price by using washers. I just need to figure out the bolt size I need now! :)
I went out and pulled one of mine for you. They measure to be English grade 5,- 5/8 x 3 1/8 . wrench size is 15/16".
/ Ordered a 5045E #59
Thanks so much!!! Very thoughtful of you! :thumbsup:
The threads, I guess, might be the other question or would all English grade 5's be cut with the same threads? At least I know they are a 5/8ths wide. That will tell me what size washer or spacer I need.
Thanks again!
/ Ordered a 5045E
Thanks again!
They are the normal coarse bolt thread not the finer machine thread. Funny that those front holes in the frame are drilled and tapped English. Those further back where the loader frame is mounted on are metric. The parts catalog clearly shows English sized bolts for mounting on a front weight rack but I haven't found a parts list for the hood guard as of yet .
2018 Dodge Charger Sedan (A61569)
2018 Dodge Charger...
2006 Freightliner M2 106 Terex Hi-Ranger HR46M 46ft. Insulated Bucket Truck (A60352)
2006 Freightliner...
1997 Ford F-450 Dump Truck, VIN # 1FDLF47F6VEB26852 (A61165)
1997 Ford F-450...
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A61568)
2006 Ford F-150...
CATERPILLAR CB24B DOUBLE DRUM ROLLER (A52707)
CATERPILLAR CB24B...
1996 Sunflower 1543-38 Folding Disk (A61307)
1996 Sunflower...
