Ordered a 5045E
/ Ordered a 5045E
Thanks so much!!! Very thoughtful of you! :thumbsup:
The threads, I guess, might be the other question or would all English grade 5's be cut with the same threads? At least I know they are a 5/8ths wide. That will tell me what size washer or spacer I need.
Thanks again!
They are the normal coarse bolt thread not the finer machine thread. Funny that those front holes in the frame are drilled and tapped English. Those further back where the loader frame is mounted on are metric. The parts catalog clearly shows English sized bolts for mounting on a front weight rack but I haven't found a parts list for the hood guard as of yet .
/ Ordered a 5045E #62
Ya, I have looked all over the net for a parts list for the hood guard without much luck! Interesting they would have metric for the frame mount and standard on the front. Now my question is relative to the bolt size again. 3 and 1/8th must be specific for Deere and I can't find a 3 and 1/8th anywhere. Did you measure from just under the top of the bolt or to the top of the bolt head? Sorry for my ignorance but sure thankful for your help! Also wondered about where to mount the guard and use the loader. I am guessing, in looking at the guard, it could be placed a little further back or a little more foreward depending on whether or not you are using a loader?? Not sure. :eek:
/ Ordered a 5045E
Hey I found it.
HOOD GUARD (5045D, 5055D, 5065E AND 5075E SERIES TRACTORS)
Cart key PART NO. PART NAME QTY SERIAL NO. REMARKS
1 AW34930 Guard 1
2 28H3481 Bushing 6 0.742" X 1.050" X 2"
3 19H2641 Cap Screw 6 5/8" X 3-1/4"
4 24M7053 Washer 6 17 X 30 X 3 mm
/ Ordered a 5045E
In the JD parts catalog search under loaders then under 9815-553 loader.
/ Ordered a 5045E
You just bolt it on. no adjustment. The loader clears it fine. it's for bumping up against the tire on the spreader your loading while your eyes are on the bucket clearing the edge. saves the battery and the radiator. :)
/ Ordered a 5045E #66
Hey I found it.
1 AW34930 Guard 1
Well, that is very helpful!!! Thanks so much!! So It is actually a 3 and 1/4 inch long 5/8 bolt then, it appears. I know they aren't always easy to measure. Washer may have been on when it got measured before. 3 and 1/4 will be lots easier to find than a 3 and 1/8th!
/ Ordered a 5045E #67
I am not totally following you here! I know you just bolt it on but it looks like you could bolt it on a little further forward or a little further back as there are 4 bolt holes on the bottom and 2 at the top that require 3 bolts. Maybe the extra holes are to fit a different model tractor. I don't know!
/ Ordered a 5045E
Just guessing here now but any extra holes are probably for some other accessory. The three you want to use each side line up the hood guard just a bit back from the line of the front tires so the tires will bumper into a flat wall before the hood guard will, at least while the tires are new.
/ Ordered a 5045E #69
I see what you are saying. I think they make the same guard for both the E and D tractors. Would think the E tractors front tires would stick out much further than the D's.
/ Ordered a 5045E
My manual doesn't give outside diameter for the various tires for the front end. A 16 inch 2WD front tire might have a longer side wall then a 4wd 24 inch tire so the outside diameters can't be determined from the rim diameter. Again I'm guessing that a 2WD tires are just a bit smaller out to out then the 4wd ones.
Who would want a 2wd tractor anyway considering the price difference and the capability difference?
/ Ordered a 5045E #71
Ya, well, I had a 2 wheel drive tractor till just trading it in for the new 5045E. Hoping it is worth the trade difference but getting a loader too will be a benefit. Just been looking around the net now for a busing about .742x 1.050x2. Doubt it has to be exact but imagine the 2 inches can't vary much but I could use a few washers instead.
/ Ordered a 5045E #72
You could get a piece of steel pipe, cut and paint it. Probably cheaper than the washers and would end up looking better
Sent from my LGL35G using TractorByNet
/ Ordered a 5045E #73
Yep, that has crossed my mind as well. I mentioned something to a buddy of mine who is a big farmer and very good with steel. He told me not to buy anything as he has the stock to make whatever bushings I need. Nice to have good friends! I just didn't want to bother him with it! Thanks for the help!
/ Ordered a 5045E #74
Well, good news, I think. I found some bushings at a local farm store that are almost exactly the same size as the needed bushings for allot less money. They are 2 inches long, 3/4 inch inside and 1 inch outside diameter. .742 is very very close to 3/4 inch and the 1.050 is very close to 1. inch so I think they will work fine. They were bushings for top links or something to increase diameter from 3/4 to 1. Anyway at 1.00 a piece, I can afford them allot easier than the 16.00 or more dollars per each Deere wants!
Couldn't find the screw so went ahead and ordered them from Deere. They are only about 2.50 per and the washers I picked up at Deere today too. Should go together fine now. Thanks for all the help. Now, If I could just find a grill guard that fits on the hood guard cheap! About the cheapest I have seen is around 125.00.
/ Ordered a 5045E #75
I built the grill guard pictured here for the cost of some 3/4" angle, welding wire, electricity, paint, and my time...the steel grate is some that I picked up at work (quarry). I bet if you asked nicely at a quarry/sand & gravel operation nearby to you, they would give you a piece of it that they have laying around. We use the stuff for everything from pulley/belt guards to catwalks. Every place we have has a scrap pile with a few decent pieces kicking around. I didn't like the coverage of the Deere guard, as it didn't cover the lower grill. Seemed pretty obvious to me that that was where the offending materials would come from 9/10 times. That's what prompted me to make my own...One word of advice, not sure if it's been covered yet so I'm sorry if it has, the grill guard will block the headlights a great deal, and I found it necessary to attach a couple flood lights to the ROPS to light up the night a little. Not sure how the picture of the sleeping kiddo got on there or how to remove it, but enjoy that one anyway...I do;-)
/ Ordered a 5045E #76
Hey I found it.
1 AW34930 Guard 1
OK, before I get real excited and order the grill guard to fit onto this hood guard, I would like to make sure this is the correct hood guard. I think it is but I am not 100% positive. The reason I am not is because the above says it is the Hood Guard for (5045D, 5055D, 5065E and 5075E series tractors)! It doesn't say anything about a 5045E!! I am pretty confident it is the right one as there isn't much difference between the 5045D and the 5045E but there is a difference, the D is 2 wheel drive and the E is 4 wheel! Hopefully I am worried about nothing but would like to have some reassurance. Thanks again!!
/ Ordered a 5045E #77
Thanks so much!! Man, you did a great job on that grill guard!! I have a friend who has the materials to make something similar, I just hate to bother him with it. I sure understand what you are saying though about the Deere guard not coming down far enough to protect everything like it should. What I though about doing is getting the Deere guard and then adding a little tray to the bottom by building one that would fit into those 4 bolt holes on the front. That would give a little more protection there and also add a place to store a log chain.
/ Ordered a 5045E #78
Thank you for the compliment!!! I always follow Red Green's motto: ''If the women don't find you handsome, they should at least find you handy.'' From what I could see, the Deere guard only covers to where the hood guard begins to bend past vertical...maybe they have changed since I bought mine, but I doubt it. Wierd that they overlooked it. I would prefer to have the mesh, as it would at least allow some light to get through to the ground if you're working around the front of the tractor, but you could simulate that with a piece of cardboard beforehand to be sure...Good Luck!!!
/ Ordered a 5045E
Great pic of the sleeping kid. They are always at their best when you have them worn out and taking a nap so you can rest too.
I've had that problem of the grill fussing the lights. I just took mine off for the winter snow plowing season and haven't put it back on. With the loader bucket on and held low it doesn't amount to much anyway as you should refrain from running into brush piles far enough for the butts to get to the grill.
/ Ordered a 5045E
As far as I can see all the 50xxx tractors today are built on the same frame with the difference being in the injector pump and turbo charger. They put on larger tires on the up horsepower versions to allow the extra power to get transmitted to the ground but all the loaders and other attachments are interchangeable. There are some differences in rear hitch in the 5075s and up but nothing I know of around the front nose.
