Tractor weight vs. finish mowing
/ Tractor weight vs. finish mowing #21
So, how heavy of a tractor have you guys used and not had bad problems with lawn rutting or how heavy was "too heavy" for you for finish mowing? .... I want to know if buying that next size up is going to cause me any additional issues other than financial :D
My two cents ... it depends. I think it really is site specific; a tractor than works just fine one place may cause damage somewhere else. A friend back east tells me his JD 3320 TLB tears up his lawn pretty easily, especially if there's been a recent rain. On my "lawn" that 3320 wouldn't bother at all. There are big ag tractors (8000 series JD and similar size CaseIH) that cross places I mow near our property to get to the fields that do surprisingly little damage. Minimal rutting and a mowing or two later, you'd never know they had been there but on the other hand there were spots on my folk's place back in Maine that a little Ariens YT-11 lawn tractor would tear up.
Type of soil and how well it drains, vegetation, terrain (hills, low spots, nearby creeks and/or ponds etc.) all enter into it. Around here the orange and green dealers will let you try before you buy- if your dealers do the same I'd go as big as you and your budget can stand/want to and work down from there.
/ Tractor weight vs. finish mowing #22
Bigger tractors typically have bigger tires too. So that said, I doubt you would see an appreciable difference in anything the sizes you mentioned.
I mow with a zero turn that weighs 1600# and my tractor with loaded rears weighs over 4000#.
I notice no difference in rutting/soil compaction between the 2 .
With the larger tires on the tractor the ground pressure/PSI are probably very similar.
I ended up buying an older Massey Ferguson 1030 MFWD with a loader. It came with R1 ag tires, 7.00-14s in the front and 11.2-24s in the back. I estimate the weight of the tractor is about 4000 pounds with the loader (which I leave on as a counterweight) and the 750 pound 6 foot 3 point rear finish mower I got to mow the yard. I mowed for the first time earlier this week and I could barely even tell where I drove over the grass. It looked like somebody drove a riding lawnmower or ZTR on the grass. I guess I didn't need to worry at all!
/ Tractor weight vs. finish mowing #24
What you do have to consider is your septic system...especially your drain field. The weight of the tractor with R-1 tire (narrower then R-3 or R-4 tires) could result in damage.
Just something to think about...if you have a septic tank and drain field.
We have a septic tank feeding a lagoon, both of which are located well behind where the yard stops and the woods begins. There is no drain field as it is too rocky; that's what the lagoon is for.
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
2008 Lexus IS250 Sedan (A61569)
2008 Lexus IS250...
2014 Chevrolet Caprice Sedan (A61569)
2014 Chevrolet...
UNUSED RAYTREE RHBC72-72" HYD BRUSH CUTTER (A62131)
UNUSED RAYTREE...
Tan Jet Dock Drive-On (A59228)
Tan Jet Dock...
UNUSED IRGC40 HIGH-END ELECTRIC MINI GOLF CART (A62131)
UNUSED IRGC40...
