bradco ground shark
/ bradco ground shark #1
05rammer
Missouri
Has anyone had much experience with the extreme Bradco ground shark, the one with the carbide teeth on the disc?
/ bradco ground shark #2
First off, this is the first time I've ever posted to a forum. I'm usually "lurking in the shadows", but I felt the need to give my two cents worth. I run an ASV SR80 with a high flow Bradco Ground Shark. I also have the stump grinder teeth option. This is the only brush hog to own, In my opinion. The only attachment more productive on heavy wood would be a forestry head. Advantages of this beast: it can process 6" softwood all day, grind the stump down to grade, grind/ mulch brush piles, has oil pressure gauge standard, and the largest bearing assembly I have seen on any brush hog. Disadvantages: extremely heavy at 2008 pounds, a little pricey (I paid $10,000), blade and stump teeth are expensive to maintain/replace. The replacement knives (4) from any dealer cost $1200.00. Absolutely ridiculous, but with some serious searching I found a machine shop that sells them for $80.00 each. Same thing with the stump teeth (18), dealer wanted $400.00. I found teeth for $7.35 a piece. On two to three year growth, it leaves a lot of stems still standing, but then again this isn't made to cut grass. Please ask any other questions. There doesn't seem to be a great deal of information about this model out there to ask people about.
/ bradco ground shark #3
I own a groundshark and when the blades got wore enough I took then to a welding shop and had then build them back up and put an edge back on --of the four only one was 2 more ounces than the others- I ground off the two ounces. the renewed edges are lasting as well as orginal.
/ bradco ground shark #4
How does it do on hardwoods? I'm wanting to buy one for my SVL90-2.
Care to post up or PM your contact for the cheaper blades? I agree the blades are way over priced, the stump teeth are marginally so.
/ bradco ground shark #5
I would say if your mowing Ash, Oak or Sugar Maple etc. your productive up to 4-5" in stem diameter. In softwood like Aspen, Buckthorn, Sassafras etc. you can cut and mulch around 8" material. Even with the stump grinder teeth on the disc, your still going to have arm sized pieces of wood from the trunk section of the tree, unless of course you have a lot patience! I found replacement blades from Lewis Machine Company in Clanton Alabama 1-800-545-4343. Their website is lewismachine.com/. Blades and shipping were just under $400.00. When you call down there, tell them there for the Bradco. I was the first customer to try them, because they are actually replacement Davco blades. The Bradco uses 3/4" material for the blades, but the Davco blades are only 5/8". They work fine, but my next order I'm going to see if they can make me 2 sets out 3/4" material. The part number is LT-732 Davco SS 705 blade 5/8" x 8" x 18". The stump grinder teeth came from Huron Quality Manufacturing in Lincoln Michigan. Their website is discountstumpcutters.com. Phone number is 1-888-467-8867. The stump grinder teeth cost $7.35 each. If any one has any other questions, feel free to ask!
/ bradco ground shark #6
I sell them at work, customers love them.
Also look at Blue Diamond. I forget the model right now (its been a long night and beer is involved), but they also have a skid mounted shredder option.
/ bradco ground shark #7
If you're trying to cut with carbide teeth and get below the ground I'd recommend the Turbo Saw. It's made by DFM and they've been doing it for over a decade. They have a hydraulically rotating head that can trim limbs as well as cut down 30" trees with a 10" a second cutting rate. There carbide teeth are rated to work in dirt or sand and they last over 200 hours.
/ bradco ground shark #8
God you spam everywhere.
I got my Ground Shark in yesterday, it's a beast!
Here's a decent sized gum, took 4 minutes to cut and process it.
Didn't time these, but still, it does great!
Here was the biggest hickory I took down. Size 14 boot makes that a 16" stump, roughly. This tree took 16 minutes to process. The blades were dull going into this tree, I'm curious how much difference that will make.
Powerstroke, I sent Lewis Machine an email asking about 3/4" blades. I will let you know what the response is. Thanks for posting the information!
/ bradco ground shark #9
No problem about the aftermarket info. I'm curious to see if Lewis Machine has any problem making any blades out of 3/4" material while set up for their normal batches. I actually want them to also carry the bevel all the way across the blade, that way I can sharpen them on my automated knife grinder.
/ bradco ground shark #13
Which Kubota is that on? Hi Flow I would presume. Carbide teeth or normal teeth
/ bradco ground shark #15
90-2 in high flow. Regular blades and the carbide teeth.
No reversing fan, but the ac fan kicks off and on.
/ bradco ground shark #16
Wow, that things really kicks it out! Guess I'm always on the inside and never noticed. That cutter works dang good.
/ bradco ground shark #17
IMG_20140323_161524_289.jpgJust thought I would post some pictures of my babyIMG_20140323_161403_797.jpg
/ bradco ground shark #18
Am I reading this right, you just got the Ground Shark but when you did the Hickory tree the blades were already dull? Let me know since I am deciding between a Diamond mower and the Ground Shark.
/ bradco ground shark #19
I had an "issue," or perhaps "conflict" is the better word, with the safety chain that fouled the blades pretty well. I took care of that issue.
The knives are nearly as sharp as chipper knives, roughly. The mowing in the video didn't appreciably wear the blades.
/ bradco ground shark #20
Ok, just trying to see which is better and that made me nervous if it wore out so fast. My Cat dealer is a Diamond dealer so they of course have their bias, but they also repair them. Bradco does not seem to have a local dealer to me... or at least the one in the area does not return phone calls when I asked about the Extreme Duty Ground Shark.
Lots of decisions... jsut getting into brush cutting/mulching... I am looking at the Diamond 72 cutter and HM315 or 415 from Cat for mulcher. Then I saw the Ground Shark... and thoughts.
2006 HEIL MC407 (A67714)
2006 HEIL MC407...
2017 Toyota Tacoma 4x4 Crew Cab Pickup Truck (A66736)
2017 Toyota Tacoma...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
2010 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2010 ALLMAND...
2016 CATERPILLAR 304E2 CR EXCAVATOR (A65056)
2016 CATERPILLAR...
2022 Kubota 62in Zero Turn Commercial Mower (A66734)
2022 Kubota 62in...
