Flow control or not, for sickle bar: Samuri/Sabre
   / Flow control or not, for sickle bar: Samuri/Sabre #21
You have to put a load on the motor to set the relief pressure.
Since the relief valve is set for 1000 psi, I would turn the relief valve screw left about two turns and check it against some bushes or shrubbery with a gage installed.
Make up a hyd test gage. About $30.
   / Flow control or not, for sickle bar: Samuri/Sabre #22
For some reason, the want the motor pressure limited to 500 psi.
I could find no reference to the lowest relief setting on the flow control valve. It comes set to 1500 psi.
The hyd motor is what develops the pressure due to the load imposed on the sickle bar cutter.
If you don't set it low, it can build up pressure greater than 500 psi, and perhaps damage some of the cutter parts.
Try it at idle and see if the cut and speed of operation is satisfactory, and if it is, just bypass the flow control valve.
This is BS. Not you JJ. ... THEM. With the torque avaiable at 500psi you could cut twigs.
larry
Would I install the test gauge on the return to tank line from the sickle?
larry
Your point is?:confused2: That the manufacturer is wrong about the stated max relief pressure of 500PSI at 10GPM?
Their recommended GPM is <4 and (150-200RPM, IIRC), basically slower than a blur of the cutters on the sickle.
So what are you suggesting should be used for speed, PSI, GPM, etc.? And how do you suggest meeting the specs with a HST fluid flow of 16.8 rated flow from my tractor?
   / Flow control or not, for sickle bar: Samuri/Sabre #25
Yes. ... Speed of the cutter must be "slow" so that stuf can enter the cutter rather than bounce off. It is easy enuf to get a slow cutter speed with a tractor having 10gpm or less capacity - just run the engine slow and pick an appropriate gear for groundspeed. With bigger tractors, or those with HST, you may need a splitter valve to get the appropriate lo hyd flow the cutter needs. Your tractor will need this.
,,,,However, in either case the hyd system must be able to deliver 2000-3000psi to the hyd motor driving the cutter. Even at 2500psi relief the cutter will stall occasionally in 1" hardwood. You can imagine how inconvenient this is when you have a moving tractor behind a stopped cutter. Repair may be necessary. A 500PSI relief would be limited to cutting twigs. -- I dont know the source of the info error from the mfg. ... Perhaps a typo. Or else ignorance has crept into their marketing side and not been caught.
larry
   / Flow control or not, for sickle bar: Samuri/Sabre #26
They say the same pressure in another PDF, and they call it high torque. Go figure.
I have a call into Samurai for some questions, and will relay the results.
Hydraulic motor 3.0 cu. in/rev. High Torque
Hydraulic oil flow requirements 3.3 gal/min at operating speed of 250 rpm
Hydraulic pressure Less than 500 psi during normal operation
High torque hydraulics cuts up to 1½“ material.
Three hyd motors used
Danfoss - #151-2121
Charlyn (H) Series - #101-1001 MSRP: $325.00
Char-Lynn Brand H-Series Low Speed High Torque Hydraulic Motors
P/N: 101-1001 4 Bolt Flange, 1" Keyed Shaft w/Woodruff Key, 1/2" NPT(F) Ports
Displacement (Cu In) 2.8
Max Continuous 1800
Torque (in-lb) @ Max Continuous Pressure 643 in lbs
Flow (GPM) 12 GPM
RPM max flow 914
Ross - #MK021310AAAB
   / Flow control or not, for sickle bar: Samuri/Sabre #27
Gage goes in the pressure side. Fluid coming out of motor is low pressure going to tank.
   / Flow control or not, for sickle bar: Samuri/Sabre #28
Let me inject a problem with Flow Control valve in question. Few days ago I posted
Need an expert hydraulic opinion.
This is what I wrote to Surplus Center:
Very recently I purchased and installed the flow control valve RDRS150-16. The purpose was to run a sickle bar attachment to my tractor. The pressure line is connected to PB of a three spool Prince MB31BB5C1 DA valve. When connected, the sickle bar (10 GPM motor) works satisfactorily. When disconnected, however, the PRV was screaming with the flow control valve was shut off. So I increased the PRV to 2000 psi, which in the beginning appeared to function okay. But at some point later, it crated a resistance that almost bogged down the engine. Of course, when this occurred, the valve was always in the off position. My understanding is that when this valve is in the off position it should not allow any fluid to pass and any remaining flow should be bypassed to the EF.
This is not happening. The only way that this valve does not create resistance when the attachment is disconnected, is when I put a jumper hose between the CF and The EF ports.
Is this valve defective?
Here is a description of my system and pics to show the hydraulic connections.
35 HP tractor, 7.2 GPM PTO pump, 3 spool Prince MB31BB5C1 DA valve set at 2000 psi, 10 gal hydraulic tank elevated about 4 inches above the valve.
That was few days ago. As of today I have not received an answer.
   / Flow control or not, for sickle bar: Samuri/Sabre #29
Did you have a QD in the CF port?
Here is some data from the valve PDF
Please note: If during operation the controlled flow port is blocked the
valve will compensate in such a way as to shut off flow to the excess port.
If you had the sickle bar mower plugged into a QD, everything probably worked fine.
If you then unplugged the sickle bar mower, the the CF flow went to 0 flow, and therefore shut off all flow and therefore, caused the relief valve to squeal.
So if you jumpered the CF and the EF, you then had flow and the relief valve would not squeal.
According to the valve schematic, it looks like if the lever is at 0 flow, then all fluid would pass out the EF port to tank.
Now what is the difference of 0 flow and no flow. or blocked flow.
   / Flow control or not, for sickle bar: Samuri/Sabre #30
I don't think there will be any trouble running a sickle bar straight from your usual QDs. This is what I have been doing for several years with my hedge trimmer. I usually run it just above idle on my JD 3520. The only addition I had to make was a direct return to tank for the hydraulic motor.
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
2017 Ford F350 (A55973)
2017 Ford F350...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A53421)
2017 JLG Skytrak...
gravely riding mower (A53424)
gravely riding...
2019 Autocar ACX Xpeditor T/A EZ-Pack Front Loader Garbage Truck (A55852)
2019 Autocar ACX...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
