Ok J_J You Won This One
   / Ok J_J You Won This One #1
Texasmark
Elite Member
N. Texas
Ford: '88 3910 Series II, '80 3600, '65 3000; '07 6530C Branson with FEL, 2020 LS MT225S. Case-IH 395 and 895 with cab. All Diesels
For those not up to date, several months ago I posted on a log splitter power unit I made out of an otherwise useless conventional riding lawn mower. I posted a pic and J_J commented on it in both a positive and negative manner. Positive was that it looked like it would do the job (which it has done), and negative was "considering I replaced the water pipe fittings with high pressure hydraulic fittings. I replied that I had been using a combination of both for over 30 years and never had a problem.
Well today I eat CROW. I have been doing heavy duty farm work with my 65 hp tractor and using a hydraulic cylinder rather than a conventional manually adjustable 3rd member. The right angle hydraulic fitting to the cylinder was just such a water pipe fitting. The cylinder has been under severe lifting stresses, lots more than the usual lift on a drag type hydraulic lift cylinder.
It was really hot and my tractor temp gauge was moving over center mark and I brought it into the watering trough to cool it off. While washing down the cooling coils, I moved around to the rear to dust that off too and saw a water pipe fitting on the hydraulic 3rd member, I had decided was the thing to use, had broken off at the cylinder.
First time in over 30 years I had a WP failure. But I did. The super slick thing about this is that it must have broken just as I stopped to cool off things. Hyd fluid was splattered all over the 3pt and all, but in checking the hyd fluid level dip stick, I was still at the upper mark. Had it broken 5 or minutes prior I would have had some serious, expensive no less, problems.
So, I reinstalled the manually adjustable member to finish cutting my hay today and tomorrow I will go to town and get some bonafide high pressure hydraulic fittings.
Is this a confession? Yes.
Do you need to rub my nose in it? No
Did I learn my lesson? Yes
Am I getting a kick out of this dialogue even though I was wrong? Yes
What else can I say but thanks J_J for your insight.
Mark
   / Ok J_J You Won This One #2
It was strictly an observation and safety thing.
Yes, people do get away with things not up to par for awhile, but then something bad happens.
   / Ok J_J You Won This One #3
Good of you to share, others can learn from your experience...
Also remember that the fittings you've been using "for 30 years" are probably a lot better than whats available today form China.
   / Ok J_J You Won This One #4
Thank you for posting this. Real world examples have more impact on people than guys spouting off specifications from a book. I'm sure there will be some other members who read this, and heed the advice. You may save them a lot of headache, and maybe something more significant.
If you can afford to wait a few days for shipping, I can probably save you a few dollars on this hydraulic fittings.
Steel Hydraulic Tube and Pipe Fittings
   / Ok J_J You Won This One #5
There are many people that will not admit to their mistakes or misdeeds.
I don't mind telling others about my commercial accident where I slid down a wet steep hill, and fell off a 4 ft ledge and the Dixie Chopper fell on top of me. My head missed an AC unit about 1 ft.
Just a few seconds and one can die and nothing one can do about it.
I survived with a lot of hurt and more knowledge than I had before.
I was real brave scooting up and down those hills, but afterwards, used much more caution.
Thanks, I picked up a dozen rt angles and straight swivels yesterday while in town. Going to backfit everything.
Mark
I don't mind tell others about my commercial accident where I slid down a wet steep hill, and fell off a 4 ft ledge and the Dixie Chopper fell on top of me. My head missed an AC unit about 1 ft.
I guess that's what separates us seniors from young "edge dwellers". I have been lucky my entire life. I have been in situations where I could have come out in a really bad way but didn't. My boys weren't that fortunate.
Mark
Thanks. Agree on the last sentence.
Mark
2013 John Deere 35D Mini Excavator (A49461)
2013 John Deere...
1043 (A50459)
1043 (A50459)
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A51039)
Neckover GL24-2-7K...
2015 FONTAINE VELOCITY 102" X 48' STEP DECK TRL (A50459)
2015 FONTAINE...
2022 Case TR340B Skidloader (RIDE AND DRIVE) (A50774)
2022 Case TR340B...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A49461)
2021 Ver-Mac...
