2014 Hay Season
   / 2014 Hay Season
Right now I'm glad for the fields that have Bahia .. Bermuda fields are suffering, I'm going to plow two of them this fall plant to wheat for spring wheat hay and then thinking about some form of hay grazer
Yeah depends on what next year looks like if I even try thin it out some. The Bermuda and coastal have sure covered what had become some poor pastures over the past few years. We put out all that Rye on the 30ac. hay meadow at house and it done good even from running 20heifers all winter on it,so we will probably put 2tons out again,banking on that early cutting on it. Even with a bad winter should be carrying over 120-140 bales into next year and I will have 20 or so stacked at house for those that may need few here and there.
   / 2014 Hay Season
How about those cattle prices,it's makes it hard keep ahold of my heifers. image.jpgimage.jpgimage.jpgimage.jpgimage.jpg
   / 2014 Hay Season
Those are last Years be putting them with bull Jan.1st,couple those I bought for $900 at 6mnths old,blacks from home,they are 16/17 now. This year not so many probably 6, I like raising my own but sure does take awhile doing it that way.
   / 2014 Hay Season #164
Heads up. I got the crop cut I showed in the pictures I took (posted herein) on June 26. Second cutting was up to about 2'. About 2 wks ago I go out to check it and it was fine. About 3 days later I go out to check it and it is a mess; plants dieing slick gooey leaf tops and bugs under the leaves. Killed the crop.
In checking around it seems that we recently acquired the "Sugar Cane Aphid". Google searching the subject you can read up on it, how wide spread it is (wide and you aren't all that far from me) and how to control it. Caught me totally off guard. On controlling it, I don't know when to apply the product but at least one farm tabloid did mention the chemical that will do the controlling. Surely looking farther into it you will find the application guidelines.
Funny comments about Bahia. I have been planting it, trying to get something to grow that I can bale when nothing else is cooperating. I think it likes the sandy acid soils better than the clay alkali soil I have.
Mark
   / 2014 Hay Season #165
   / 2014 Hay Season
I don't know where they are today, but in February I got $2400 for a 3 year old 7/8 Angus Brahman cross grade bull in Durant, OK. WAS impressed.
Mark
They would probably bring $1600. I been keeping my own for couple years,instead of buying,so that will make me have change black bulls about March ,I raised a composite bull and he is on some cows ,see what he is going to throw. Going to look into the 44farms angus bulls. Would like to buy maybe 15head bred 2/3yr olds angus/brangus/baldies some nice uniform group.
   / 2014 Hay Season #167
Around here "black is boss". My daddy graduated from TAMU in 1929. Did his stint in WWII as a Captain and in '45, upon getting released, built his own Barbecue Steak House. Specialty was Kansas City prime aged Angus. He taught me then the advantages of small bones, thick structure, high marbling and all for flavor and tenderness and here it is some 65+ years later the brand is finally being featured in your local super market. Absolutely amazing.
Mark
   / 2014 Hay Season
Laid 10+acres down on the 20acre meadow,have some rain chances Tuesday so didn't do all of it. Working with local guy to buy everything it makes...
   / 2014 Hay Season
   / 2014 Hay Season
It sure didn't take it long to cure out. I did ted it at 10am this morning and started baling at 5pm. It still made better than I figured,I was thinking 30 and it made 34 almost 35. They moved rain from Tuesday to later week wish I would have went ahead and cut the rest now.
Voltage Converter, Single Phase, 240 Volt Input, 120 Volt Output (A59076)
Voltage Converter...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
IRON FORCE IMPACT SET (A58374)
IRON FORCE IMPACT...
LOT: Kimball Midwest 4-Drawer Hardware Cabinet w/Contents & Stand (A59076)
LOT: Kimball...
2019 MACK GRANITE (A58214)
2019 MACK GRANITE...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
