Good morning!!!!
   / Good morning!!!! #23,771
82* and humid. Horses are fed and out, and chickens are now out and about. Should be going to 100*+ again today. Yesterday was 107* per our thermometer. Can't believe some of the temps you fellas are reporting. Especially in August.
   / Good morning!!!! #23,772
58F & cloudy. Had light rain overnight, maybe some scattered showers this afternoon. Next week is looking dry and mostly sunny which is good news for the field project.
I'm not sure if I would make bail for Drew or not ... hmmmm :laughing:
RoMad, good luck on your shoulder recovery. Achy shoulders that have to be babied are no fun.
   / Good morning!!!! #23,773
70*F here this morning. Woke up to a thunderstorm. Suppose to stop raining mid morning but cloudy all day. Temps will struggle to reach 80*. Gotta love August. Tomorrow more rain 85* then rest of week is 90*+ with chances of rain. Bet it gets foggy for the last half of the month. So far hasn't been bad.
Haven't really followed this thread much but seems like a very interesting one. Nice to see what weather is doing and where.
   / Good morning!!!!
Morning guys! Got my mowing done yesterday, need to do some chores outside, then work cleaning out the garage. Have a good one!
   / Good morning!!!!
If it got 107 f here, I think it would kill people and animals. We just aren't used to that level of heat. I'd just hide out in the house.
   / Good morning!!!! #23,776
It has been a very mild and wet August compared to normal. Only going to be 81F today and a chance of rain forecasted for the next ten days...
   / Good morning!!!! #23,777
68f and .29 inches rain last 24 hours. Morning rain just stopped, sun trying to peak thru.
Be safe
Have a great day
David Sent from my iPad Air using TractorByNet
   / Good morning!!!! #23,778
Good morning. 1150, scattered clouds, 88F with 68% humidity. Forecast high of 91F with 40% chance of thunderstorms this afternoon, and a low of 74F tonight. We have had one passing shower while I've been sitting here at my PC, and there is a dark cloud moving in from the west now. The cool weather still hasn't made it's way down here to me. We will be near triple digits by next weekend.
I have the rare Sunday off while Margie is having to work. She has to do one Sunday of early voting, and decided to do it today rather than right before election day. I worked till after midnight, and didn't sleep in as late as I would have liked. And since I'm waiting on her to start watching the race, I'm thinking about a nap before lunch. Knowing my luck, the phone will ring as soon as I get to sleep.
Hope everyone has a good day.
Larro
   / Good morning!!!! #23,779
Larro
1 Lap to go now before the start...I'm watching now....I can't wait for you and Margie...sorry Larro.....LOL
   / Good morning!!!! #23,780
73 and cloudy @ 13:45 ...
It's apparently been raining on and off this morning ... spotty showers. Was supposed to clear up this afternoon and get sunny ... doesn't look like it's happening so far.
Spent most of yesterday afternoon working on the lawn ... cut the upper front yard with the Kubota first and then mowed all around the house with the Simplicity. Then windrow'ed what the wife had cut on the lower front yard the day before ... and then did the same for the upper front yard I had cut earlier ... about the time I was finishing that she got home from work with dinner.
After I ate I hooked up the Trac Vac and she started picking up the windrows ... it got dark and I ended up having to pull out the magnetic light bar and mount it so she could see what she was trying to pickup.
Worked up in the shed until about 04:00 ... pulled the gearbox on the Milwaukee angle grinder apart ... the ring and pinion gears were both dry as bone ... no obvious metal flakes or chips, but some of the grease (which is yellowish) was discolored (blackish) ... the gears appeared to be in decent shape (without having new ones to compare them to), so I took a small screwdriver, a pick/probe, and paper towel and dug out as much of residual grease that was in the housing as I could and repacked it with Milwaukee "Type Y" grease and put it back together. I then pulled the plastic covers on the motor and checked the brushes ... they looked to be better than 50%, so I put that back together and gave it a test drive ... sounds way, way better ...
This is easy enough to do - no small parts came flying out when I took it apart - that it ought to probably be done on a more regular basis (yearly) if the tool gets a lot of heavy use. The only possible hazard I saw was the needle bearings for the ring gear shaft - have to be careful that they stay where they are supposed to ... but they don't seem inclined to wander as they are covered with grease anyways.
Reassembled the filter and swirl ring for the (China ?) filter/regulator for the plasma ... that ended up being a bit of a challenge, as pieces flew when I originally took it apart and I couldn't find a manual for it. Also cleaned out and installed the filter screen for the Schrader-Bellows air filter that I had missed installing when I originally reassembled it.
Had a little plastic bin that all my hex keys had gotten tossed into for cleaning a number of years ago ... went thru that and wiped them all down with a rag and the Murphy's Oil Soap/water solution that I use for cleaning. Still need to hit them all with some fine steel wool to remove any rust corrosion and then coat them with a little mineral oil.
Last thing I worked on before I called it a day was an old Kal Equip vacuum/fuel pump pressure gauge. I had three of these that I purchased back when I was around 20 years old to set the carbs on my Yamaha XS750SF Special. The case had some rust and corrosion where the paint was lifting and the plastic "glass" was covered with paint overspray. I used some Duplicolor Grease and Wax Remover and a rag to clean off the overspray on the "glass" and then took it apart and wire wheeled/steelwooled/sanded the case to remove the rust in preparation of repainting it. Got most of the way there and then decided it would probably be a good winter project ... so I bagged it up and stuck it in the tool chest.
More cleaning and putting things away on the menu for today.
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
2008 TEREX USA LLC LIGHT TOWER (A50854)
2008 TEREX USA LLC...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
