X310 and X360
/ X310 and X360 #1
James Runchey
Still trying to decide on a new one. What do i gain between the 310 and the 360? The lower price appeals, but is it worth it? My property is not very hilly, not too large, easy to cut. iI want to get a snow blower also.
/ X310 and X360 #2
I would get the X310 based on where you will be mowing.
/ X310 and X360 #3
For the price (extra 1300 msrp) you get 3.5 extra hp, 2" taller tires, a low fuel light, tilt wheel, 6"wider deck with 90 degree rotatable wheels with 3 more positions on the settings of the deck wheels, both use the K58 transaxle, 44" blower and same other tools.
/ X310 and X360 #4
Having read both of your threads I would suggest the x310, less cost and good enough for a smaller yard. I can only assume you have gone through the whole tractor experience with your prior farm so you are not trying to buy a tractor. An x310 with the smaller deck might be easier to mount and dismount later on. Definitely takes less room to park if the shed is small.
A couple of times a year you may need your son's help with blades and attachment swaps, good excuse for a little time to talk and visit.
/ X310 and X360
How easy is it to remove the mower deck on the 310? The 54' Deck on my 345 just rolled out to the side, which was very easy. Do the wheels rotate on the smaller decks?
/ X310 and X360 #6
The anti-scalp wheels don't rotate but the deck is fairly light and maneuvereable.
/ X310 and X360 #8
The one thing I wished I had considered prior to purchasing the x320 4 years ago was that the k58 tuff torq transmission is not owner serviceable, not sure if this applies to the models you are considering. Have driven it up and down bill hills on 2+ acres for 180 hours, and it has slowed down, ultimately suggesting the transmission need to be serviced, after replacing belts, verifying linkage, etc. My options include having the dealer do it, or follow various work around posted in the forums to enable me to chnage the trans fluid. I would personally not buy another machine that did not allow this basic maintenance feature out of the box. Hope it helps.
/ X310 and X360 #9
On a K58, the fluid and filter can be owner serviced.
What other services are you looking to do? Just curious.
/ X310 and X360 #10
mikepa,
The x320 manual I have indicates no such owner serviceability for my k58 in the 2010 x320, it is a "sealed unit". See here http://www.mytractorforum.com/showthread.php?t=55915 and here TractorData.com John Deere X320 tractor transmission information and particularly here http://www.mytractorforum.com/archive/index.php/t-179552.html (very similar to what I have experienced in terms of degraded performance over time).
There is no fill tube, and no drain plug, only a breather vent that some have used to drain and fill the unit, after taking it out and tipping it on its side to extract the fluid. The major difference with the x320 and x500 line is the k72 tranny does have a drain plug and fill tube.
JD using a transmission that is sealed and does not allow the normal owner replacement of fluid out of the box is a fundamental flaw. Fluids degrade with use over time and transmission component wear and eventual failure is likely at some point without the ability to replace the fluid.
Thx
/ X310 and X360 #11
Interesting. The current x310 and x320 have k58 transmissions that are serviceable. I agree they should always have been.
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A63276)
2017 FORD F-350 XL...
JCT Skid Steer Tiller (A64047)
JCT Skid Steer...
MOBILE HOUSE SKID (A63569)
MOBILE HOUSE SKID...
2014 Nissan Quest Van (A61574)
2014 Nissan Quest...
Unknow Lot 7694 (A64047)
Unknow Lot 7694...
2008 PROGRESSIVE 20' X 7' BUMPER PULL TRAILER (A63569)
2008 PROGRESSIVE...
