Spare key - CK22-HST
/ Spare key - CK22-HST #1
cavalcade
Kyoti CK22 HST
Hello,
I live in France, and thanks to a messy separation from my partner she's hidden the keys to my tractor. The usual local dealer I use is shut for August (this is normal in France) and other dealers I've tried claim the CK22 doesn't exist (CK20 yes, CK25 yes, CK22 no). I also can't find anywhere in Europe that even stocks Kioti spare parts. Any ideas?
The tractor has been sitting outside for days as I had to repair a problem with the hydraulics, but now it's just sort of rusting away in a field and I desperately need it to manage the farm I have.
/ Spare key - CK22-HST #2
Most tractor manufacturers use the same key on a lot of different models. I would try a key from a CK20 or a CK25. A this point you have nothing to loose.
/ Spare key - CK22-HST #3
You may have better luck hot-wiring the switch - or, just replace the ignition switch.
/ Spare key - CK22-HST #4
Replacing the switch is OK, but I would not try hot wiring. The switch has multiple "output" wires for crank, glow, stop solenoid, accessory, etc. It's hard to get all that right if you hot wire.
/ Spare key - CK22-HST #5
Correct.
They all very likely use the same key
/ Spare key - CK22-HST #6
I had to replace the ignition switch on my CK30hst and the new one had the same key cut as the old one. The CK20 was a smaller frame tractor compared to the CK25, CK27, CK30, and CK35 but I believe used the same switch and most likely the same key. Any one of these should work.
/ Spare key - CK22-HST #7
I received only 1 key with my new DK50. Getting another was quite a challenge. It seems there are at least 3 different keys, and mine uses the latest variety - which the dealer did not have and did not know.
/ Spare key - CK22-HST #8
Hello,
Try this; I've used my kioti key to start and run a JCB back hoe and visa versa! OR, if you know someone who has a kioti, barrow his/her key. Believe it or not almost all kioti's have the same key cut (simular to cat, deere, case etc.) I have 2 keys; 1 from my ol' ck20 that I traded in and the one that came with the ck30------both have the same cut!
(1) 30 Yard Roll Off Dumpster (A65579)
(1) 30 Yard Roll...
2006 GREAT DANE 48' T/A FLOAT TRAILER (A65643)
2006 GREAT DANE...
(1) Small Livestock Feeder Gate (A66408)
(1) Small...
Toro LX460 Riding Mower (A65579)
Toro LX460 Riding...
13ft. Disc (A65640)
13ft. Disc (A65640)
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A64194)
2022 Power Screen...
