Teikas Dad
Gold Member
I recently bought a used pickup to tow the trailer that I'm going to buy for my tractor. I want an 18' flatbed trailer and the only ones I can find are rated for 7000lb GVW. With the weight of my T/L/B and the trailer combined I'm right at about 4900lbs. I figured that was too close to the limit on a 5k lb rated trailer, that's the reason for going bigger.
My question has to do with the hitch receiver on the truck. The truck is a 2000 and going by the date on the Reese hitch that is on the truck, the hitch is a 2006 model. It's the universal fit type receiver hitch where there are two brackets that bolt to the frame of the truck then the center of the receiver, which is a large round tube with the receiver welded on, mounts inside the frame brackets. The hitch is rated for 5k W/C and 7k L/D. There are two flat plates on the end of the center tube that get bolted to the frame bracket with 4 bolts on each side. Here's what the center tube looks like:
This is what it looks like with the frame brackets bolted on:
I took the receiver/hitch off the truck as I want to clean it up, repaint it and I'm going to replace all the bolts with grade 8 bolts as the existing bolts were a bit rusty. After I took it apart I started thinking about welding the center tube plates to the frame brackets in an effort to strengthen the receiver. I'm not looking to increase the GVW of it, I just want to make sure that the bolts don't shear and leave my tractor and trailer in a ditch someplace. I contacted Reese and they only use grade 5 bolts so just going to grade 8 will make it stronger but I tend to overthink and over do everything.
Am I better off to leave well enough alone and just go with the grade 8 bolts or would bolting it together then welding the crosspiece plates to the frame brackets be a better way to go?
I'm going to post this on the trailer thread too for all the towing experts to comment on.
Thanks
Thanks
