LED Trailer Light's
/ LED Trailer Light's #1
jrepp44
NW Louisiana
Kubota B2650HSTC
I want to replace my old corroded incandescent lights with LED's. Any recommendations on good lights or light kits? Thanks.
/ LED Trailer Light's #2
/ LED Trailer Light's #3
Dont buy chinese crap. My brother renovated a dumptrailer, installed LED lights from a china import shop thinking he never had to check lights before hitting the road, again. Turns out the soldering of the LEDs on the circuit boards, cant take the vibration of driving on the road. On one rear light only a few LEDs still burn, only after 3 years of limited use
/ LED Trailer Light's #4
Also be sure they will fit.
My Hudson trailer has the light "boxed" in and I haven't found a 4" LED tail light that fits. I called Hudson and they said they didn't know of one.
/ LED Trailer Light's #5
I switched to LED lights on 2 of my trailers and I'm glad I did. I'm not sure what brand they are. I picked them up at my local trailer dealer.
The only issue was the cost. The LED's were about $35 each, compared to about $7 each.
/ LED Trailer Light's #6
I always find that going to some place like Autozone or an auto parts store helps get the imagination going on what you think you'd like. Then go from there. Trailer lights aren't difficult. Just match up the colors!
/ LED Trailer Light's #7
I changed 100's. Cheap to expensive they have all worked the same, GREAT!
Chris
/ LED Trailer Light's #8
I to was going for LED lights ,but as often as the trailer comes back without them;I will stick with harbor freights cheap knock em off type. Loading or unloading always gets one and I am down to only being able to knock one off when backing up.
/ LED Trailer Light's #11
I have always had problems with the bulbs in regular lights but after changing to LED's I have not had a problem since. It has been over 2years.
John
/ LED Trailer Light's #13
I replaced many of the bulbs in my camping trailer with LED's. I pay about 9-12 bucks a bulb on amazon from ones with many good reviews. I often boondock and need the battery savings from LED's.
/ LED Trailer Light's #14
Everything seems to be 4 5/16" in diameter.
Thus I need to fit it inside the "box".
Those replacement bulbs sound interesting.
/ LED Trailer Light's #15
I've put these lights on two fifth wheel campers and one utility hauling trailer - 10 Diode Surface Mount Red LED Stop Turn Tail Light RV Trailer Truck Cargo RV | eBay
They're very bright, sealed very well and to this point, almost bullet proof. I've done a lot of driving on rough roads, nothing has shaken loose so far.
I bought a set of the replacements for an 1157 bulb awhile back and they just didn't impress me at all, and even if they did, you'd still have the possibility of corrosion in the socket, etc.
/ LED Trailer Light's #16
Yeah I thought of that corrosion too, but you can install the bulb covered with grease and it should be OK. However, 100% sealed seems better. LED 1157s work pretty well in my opinion. But I have some broken light housings and want to replace all. I like LED trailer lights because they take so little power to operate, and they are bright. Thus even if your trailer plug is corroded the lights are still bright.
I am hoping that HF have figured out (by now) how to build a LED circuitboard that will withstand vehicle vibration.
Newbury I have the same situation, looking for an inexpensive light that fits in the box. I plan to use Harbor freight "insert" lights and discard the black ring, and just silicone the light housing directly to the steel light bracket, then cover the box with a protective screen.
4" Submersible LED Stop/Turn Trailer Tail Light
Heres some pics and dimensions of the lights I bought at Harbor Freight. These same lights are all over the web for about the same price ($15 each). 4 5/16" is the actual (accurate) diameter of the light housing.
385572d1407422091-led-trailer-lights-harborfreight_tail-jpg
/ LED Trailer Light's #17
What about a led replacement 1157 bulb?
I would ONLY use Amazon.com: Philips 12899RX2 X-treme Vision LED Red Rouge Intense Stop Light Bulb for 1157 P21/5 (pair): Automotive for an 1157 replacement bulb.
I have some generic ones from Amazon that had good reviews, but there is almost no differentiation between "high" and "low" (as such, its almost impossible to see the brake/turn light when the running lights are on.
If you need a single filament red bulb, try: Amazon.com: Philips (12898RX2) Red P21W LED Exterior Bulb: Automotive
For white ones, try: Amazon.com: Philips 12898X2 X-treme Vision LED 6000K 12 Volt Xenon White Backup Light Bulb for 1156 P21 (pair): Automotive
Aaron Z
/ LED Trailer Light's #19
well -- how often do you use the trailer and does size matter? I bought these two years ago LED Trailer Light Kit - Includes Wiring & LED Trailer Lights . I used the taililghts from the kit and tossed the rest in my stash. I used the trailer at least 1-6 times a month during spring thru late fall. I towed firewood home once or twice during first snowfalls with no salt on roads yet too and no problems with it since.
/ LED Trailer Light's #20
I switched all the lights on my 20 year old flatbed car hauler to LED's. I went with slim line ones, and they were much smaller than stock. I was worried about visibility, as they are half the size of the originals. The new LED's are WAY brighter than bulbs, I can see the glow on the trailer and ground in my rear view mirror much better, and after 3 years, still zero issues. I got them off ebay, and they were pretty inexpensive. Well worth the change
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
FLAT BED (A60736)
FLAT BED (A60736)
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61307)
2017 Yale GLC050VX...
